-   -   Plumbing runs on basement outside wall (http://www.diychatroom.com/f7/plumbing-runs-basement-outside-wall-130087/)
n0c7 01-15-2012 01:47 PM
I want to run hot and cold PEX lines down a 2x4(wood) batt insulated "outside" basement wall to where my builder has roughed in a sink drain. I know that running plumbing in exterior walls above grade is usually not allowed but does this apply to the basement? If I'm allowed, what precautions do I need to take?
I live in a winter climate that gets very warm in the summer to sometimes arctic cold in the winter.
joecaption 01-15-2012 02:05 PM
Very bad idea, They should be if at all possible run down the center of the crawlspace and in your area I'd also insulate them with foam tubes.
n0c7 01-15-2012 02:18 PM
Sorry when I said outside wall I didn't actually mean outside. It's on the interior of the house foundation walls.
joecaption 01-15-2012 02:27 PM
Where are yu most likly to get air leaks in a crawl space?
Any cracks, gaps under the foundation plate, any vents. Moving cold air is what's going to freeze those pipes.
TheEplumber 01-15-2012 03:13 PM
199 Attachment(s)
When you drop into the wall, stay to the warm side of the insulation- against the drywall. Be sure the rim joist is insulated well.
n0c7 01-15-2012 05:04 PM
Here's a pic of what I'm working with:
http://i62.photobucket.com/albums/h82/n0c7/photo-3.jpg
Should the pipes be behind the vapor barrier or in front?
joecaption 01-15-2012 05:25 PM
In front
n0c7 01-15-2012 05:42 PM
Originally Posted by joecaption
In front
Now that you've seen a picture - were we talking about two different scenarios?
n0c7 01-19-2012 05:22 PM
Local authority says in front of the vapor barrier but behind the drywall. Not sure how you clamp it down like this but hey.
