Plumbing Rough In Versus Final Inspection - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2012, 01:43 PM   #1
Hello, what would the difference be between a rough in plumbing inspection and a final plumbing inspection when installing a bathtub, toilet, double sink, and hot water heater?
Wouldn't the hot water heater, tub, and all other supply lines need to be connected and all the drain lines run to pass the rough in inspection?
Thank you for your help!
kingbuggy is offline   Reply With Quote
Old 06-21-2012, 03:15 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by kingbuggy View Post
Hello, what would the difference be between a rough in inspection and a final inspection...
rough looks at what is in the floors, walls, ceilings,and will later be covered up.
final looks at what was done after all is covered up
Old 06-21-2012, 03:30 PM   #3
Rewards Points: 141
water test?
Maybe it depends on your county/city, but a DWV water test might be required - although i'm not sure if it's a final or a rough-in inspection item.
RocketGal is offline   Reply With Quote
Old 06-21-2012, 09:56 PM   #4
DWV is a rough-in test.
VIPlumber is offline   Reply With Quote
Old 06-23-2012, 03:48 AM   #5
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
here in cali rough=below slab,waste, water and sewer top out=waste, vents, water,gas, condensation,setting tub/shower,rough in valves every thing before sheet rock is hung except for test of gas line, inspector will check on install but the pressure test is at finish or some call it trim. finish=set all remaining fixtures ,sinks, w/h , faucets ect
wctekkk is offline   Reply With Quote
Final Inspection Questions docmattman Building & Construction 6 07-15-2010 07:11 PM
Final Inspection WWilson Building & Construction 3 07-07-2009 04:27 PM
Passed my rough inspection, now what? theatretch85 Electrical 12 05-03-2009 02:11 AM
Final Inspection requirments K&G's Cabin General DIY Discussions 1 01-28-2007 01:44 PM
Need Advice for Final Inspection Bobby General DIY Discussions 5 09-22-2006 02:50 PM
