Plumbing Rough-in For Vanity - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2010, 06:40 PM   #1
Rewards Points: 41
plumbing rough-in for vanity
Greetings,
I'm plumbing for a bathroom vanity. I know that the sink will be exactly in the middle of the vanity, so I know the sink location. I will be using wall-mounted lavatory fixtures (example: K-410K) with two faucets and a spout.
How does the sink vent (1.5-inch ABS) go up past this plate?
While we're looking at that problem, I have a related question about the "tee" to which the trap below the sink is connected. Where should this tee be located with respect to the sink? Right on the centerline of the sink, or does offset by some amount work better?
If someone could point me to some drawings of common rough-ins, maybe that would answer my questions.
Tom
tom31415926 is offline   Reply With Quote
Old 12-13-2010, 08:33 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 546
I try to rough in lavs using the method shown on right. It allows for vanity lights, medicine cabinets, and in your case, wall mounted faucets. If your vent is already installed, use 45's to offset around your faucet.
As far as your tee goes, center it or go up to about 2.5" to one side. Any more and you'll be adding a fitting to line it up again.
The Following User Says Thank You to TheEplumber For This Useful Post:
tom31415926 (12-13-2010)
Old 12-13-2010, 11:35 PM   #3
Rewards Points: 41
Thanks, Eplumber!
I think I see what's going on - the vent can go 90 degrees to one side, then up. But it will have to cross a water supply pipe, should be just enough room.
Is there a full-size image of the one you posted? It's a little hard to see.
Thanks again.
Old 12-14-2010, 08:38 AM   #4
Plumber
Rewards Points: 546
Originally Posted by tom31415926 View Post
Thanks, Eplumber!
Thanks again.
http://www.plumbing-geek.com/trap-arm.html
To be code compliant, you need to be 6" above the rim of the sink before you 90 horizontal. 45 degree is still considered vertical though
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 04:39 PM
Basement bath plumbing rough in allowing ground water to enter VooDu Plumbing 1 01-07-2010 01:09 PM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 08:30 AM
rough in plumbing psiter Plumbing 5 08-23-2006 05:44 PM
