Plumbing Rough-in Identification Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2013, 11:34 AM   #1
Jackof-all Masterof- none
Post
Plumbing Rough-in identification help
Hey all,
I've read a lot of other posts and viewed their pictures. I am finishing my basement and have some plumbing rough-in down there. I was wondering if anyone would mind helping me identify the individual pipes. I have attached a picture and here is what I believe they are. It is a "half-bath rough-in"; The pipe at the upper most part of the picture is the toilet pipe. The pipe in the middle of the three, along the wall is the vent pipe, and the one closest to the bottom of the picture is the sink drain. Any comments?
Also, how difficult is it to run a shower drain with this set up? I have tapped around the area with hammer and I do not have any hollow sounding spots where there may have been a pipe/drain placed and covered with cement. I don't know for sure, but I think this might be a hire out job. But, I really enjoy doing my own work....So, if its managable I will do it.
Pigonahog is offline   Reply With Quote
Old 01-21-2013, 11:39 AM   #2
Roofmaster
Rewards Points: 2,172
You are kidding with this picture right?
Old 01-21-2013, 11:43 AM   #3
DIY staff
Rewards Points: 7,174
Posting good pictures is not as easy as jack hammering a floor and installing pipes.
I've done countless floor piping jobs--yet never could post a picture here.
Beepster (01-21-2013)
Old 01-21-2013, 12:10 PM   #4
DIY staff
Adding a 2" drain and vent for a shower should not be to difficult----the main drain is the toilet pipe---
Use masking tape or something to do a sample layout----then try those pictures again---
Old 01-22-2013, 08:02 AM   #5
Some have a hard time with limited information!
Apparently the base information is tough to work with. Sometimes, I forget the forum that I'm in. If you can't help regarding the posted picture, you shouldn't waste your time with a weak response.
Old 01-22-2013, 08:03 AM   #6
Thanks oh'mike. I'll do that and submit another picture.
Old 01-22-2013, 08:47 AM   #7
Roofmaster
Yes of course you are correct. I should have said:
In order for anyone to be able to help you, it would be much more beneficial to back off, and take a wide angle shot to give the general layout from an eye level perspective, as if you have stood back and presented the problem on a wide palette. You could then get closer and, placing a yardstick or ruler for reference, show the relative position of your stub outs (Pipes) relative to your walls.
It does at times become very laborious posting pictures because of the absolutely ludicrous size limit of 100KB, and this probably discourages most people from posting pictures at all. 400kb would make a lot more sense.
Old 01-22-2013, 09:08 AM   #8
Rewards Points: 352
lavatory drains can tie in to the waste stack above floor level. If the smaller drain in the floor is 2" it is probably a shower drain. Look inside of it and see if it is trapped
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
Pigonahog (01-23-2013)
Old 01-23-2013, 01:22 AM   #9
Oh'Mike - that many posts and no pictures? Wow!
profcolli is offline   Reply With Quote
The Following User Says Thank You to profcolli For This Useful Post:
oh'mike (01-23-2013)
Rough in plumbing pre test? 1dumbquestion Plumbing 2 01-20-2012 08:12 PM
Installing Plumbing in a basement with No rough ins simpsjm1 Plumbing 8 12-20-2011 10:40 PM
basement plumbing rough in smacameron Plumbing 3 11-20-2011 05:34 PM
basement plumbing rough in - what are these pipes? skypilot84 Plumbing 1 10-12-2010 11:59 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
