-   -   Plumbing Rough-in identification help (http://www.diychatroom.com/f7/plumbing-rough-identification-help-169715/)
Pigonahog 01-21-2013 11:34 AM
1 Attachment(s)
Hey all,
I've read a lot of other posts and viewed their pictures. I am finishing my basement and have some plumbing rough-in down there. I was wondering if anyone would mind helping me identify the individual pipes. I have attached a picture and here is what I believe they are. It is a "half-bath rough-in"; The pipe at the upper most part of the picture is the toilet pipe. The pipe in the middle of the three, along the wall is the vent pipe, and the one closest to the bottom of the picture is the sink drain. Any comments?
Also, how difficult is it to run a shower drain with this set up? I have tapped around the area with hammer and I do not have any hollow sounding spots where there may have been a pipe/drain placed and covered with cement. I don't know for sure, but I think this might be a hire out job. But, I really enjoy doing my own work....So, if its managable I will do it.
jagans 01-21-2013 11:39 AM
You are kidding with this picture right?
oh'mike 01-21-2013 11:43 AM
Posting good pictures is not as easy as jack hammering a floor and installing pipes.:laughing:
I've done countless floor piping jobs--yet never could post a picture here.
oh'mike 01-21-2013 12:10 PM
Adding a 2" drain and vent for a shower should not be to difficult----the main drain is the toilet pipe---
Use masking tape or something to do a sample layout----then try those pictures again---
Pigonahog 01-22-2013 08:02 AM
Some have a hard time with limited information!
Apparently the base information is tough to work with. Sometimes, I forget the forum that I'm in. If you can't help regarding the posted picture, you shouldn't waste your time with a weak response.:thumbdown:
Pigonahog 01-22-2013 08:03 AM
Thanks oh'mike. I'll do that and submit another picture.
jagans 01-22-2013 08:47 AM
Yes of course you are correct. I should have said:
In order for anyone to be able to help you, it would be much more beneficial to back off, and take a wide angle shot to give the general layout from an eye level perspective, as if you have stood back and presented the problem on a wide palette. You could then get closer and, placing a yardstick or ruler for reference, show the relative position of your stub outs (Pipes) relative to your walls.
It does at times become very laborious posting pictures because of the absolutely ludicrous size limit of 100KB, and this probably discourages most people from posting pictures at all. 400kb would make a lot more sense.
plumberinlaw 01-22-2013 09:08 AM
lavatory drains can tie in to the waste stack above floor level. If the smaller drain in the floor is 2" it is probably a shower drain. Look inside of it and see if it is trapped
profcolli 01-23-2013 01:22 AM
Oh'Mike - that many posts and no pictures? Wow!
