Plumbing Rough-in For A Concrete Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2012, 01:28 PM   #16
Originally Posted by DannyT View Post
which side is the sewer connection on?
where is the water heater going?
is this going to be on a slab or raised with a crawl space?
the bathroom can be vented with one and the kitchen needs one also.
depends on where you need the floor drain. why do you need a floor drain for the water heater?
Just figured out how to use the "quote " button.
Hi Danny,
The heater is going in the bottom right hand corner of the plan( I know, I need to improve the drawing but don't have the technology yet). The heater will be for in in floor heating. I would like a drain in that corner in case the hot water tank blows. Also, it's a code requirement here :). I would also like to tie into that drain and run a pipe in the wall in case I want to install a little washing machine in that corner.
This is a slab, so of course it's VERY important that I plan this well!
Thanks for your input!
JennP is offline   Reply With Quote
Old 09-02-2012, 01:41 PM   #17
Originally Posted by Alan View Post
You do realize even with a concrete floor you will still need to protect the floor with a proper shower liner system? If you do not, the oils and soap scums that you rinse off of your body will absorb into the concrete and make it stink. You need to figure your recess of the shower based on the size of the shower, as the sub base of the shower will need to be sloped so that the liner will be sloped, as well as the finished surface all 1/4" per foot. The overall thickness of the drain you get will make a big impact on the depth.... 2" does not sound like enough to me.
I didn't know I would need a liner for this. Couldn't I just seal the cement with something to make it impervious rather than a full on liner? It could be tricky finding a liner to suit, and custom made would be costly.
Old 09-02-2012, 01:50 PM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you're not using a fiberglass pan, then you need to "Make one" using approved methods and materials read : (custom). Those are your options. If you opt out of using any kind of a pan system, do expect that the concrete will absorb all of that crud and become very smelly. Concrete is very porous and I assume that even with the best sealing methods, water will find a way into the concrete anyway.
I saw your post about a floor drain in case the heater blows : Using a floor drain is fine, but with a floor drain you'll want a trap primer to keep the trap from drying out and stinking up the house. Your other option would be to put the water heater in a pan, and plumb a drain from the pan out of the building above grade. This will be much cheaper, and will work just as well, assuming the heater is going on an outside wall.
I made a quick sketch of the way I would plumb it (attached). Not sure if it meets code in your area or not... I figure the sewer entering the building about 2-1/2 to 3 feet from the corner of the building under the sliding glass door.
Journeyman Plumber
Old 09-02-2012, 02:20 PM   #19
Thanks Alan,
It seems like I will have to sort out a liner for this shower. Happy to find this out now rather than later with a stinky bathroom!
Running the hot water tank drain outside the slab is a good idea, i will do that. And as far as having a drain for a washing machine goes, I don't think I really need a drain because the small kind of washer that will fit in this place could be the type that just hooks up to the kitchen sink.
I'm finding the plumbing sketch hard to read. It's not clear to me where the drains tie into the system, particularily in relation to the toilet.
Old 09-03-2012, 08:23 AM   #20
DIY staff
Rewards Points: 7,174
To waterproof the concrete----there are many ways---if you tile it--use a paint on waterproofing like Hydroban by Latacrete or one of the other good brands----
Old 09-05-2012, 03:22 PM   #21
Rewards Points: 141
Open a pdf file
To oh mike and others who need to open a .pdf file occasionally: http://get.adobe.com/reader/ at this site you can download free software that you can install on your computer so you can automatically open and read .pdf files. Adobe Reader is what you need. (Click no to refuse any add ons that you don't want.)
RocketGal is offline   Reply With Quote
The Following User Says Thank You to RocketGal For This Useful Post:
oh'mike (09-05-2012)
Old 09-06-2012, 12:14 AM   #22
I just watched a 10 min youtube vid on the Hydroban and it looks as though that will work for me. Thanks oh'mike for the info!
The Following User Says Thank You to JennP For This Useful Post:
oh'mike (09-06-2012)
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 05:24 AM
Relocating plumbing - concrete slab foundation vsheetz Building & Construction 17 04-23-2011 06:22 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 11:06 AM
