Plumbing: Relocating The Washer Machine!!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2010, 12:01 PM   #1
Plumbing: Relocating the washer machine!!!!
Hello, My house was built in 2001, and I live in Miami, Fl. We do not have basements. l would like to relocate the washer machine to the garage. How do I work the plumbing? The washer machine is presently inside the house in a small "laundry closet" . I would like to convert it into a powder room/guest bathroom. I need an estimate in price and time or do it myself tips.
A household of six
powder room is offline   Reply With Quote
Old 09-03-2010, 06:03 AM   #2
We don't do estimates here. And since most of the pipes are in the slab, making that move will be messy and expensive, unless you are good at cutting concrete. One option might be a large gray water pump to pump the water to drain pipe. But careful, you can't make unsealed(fireproof) holes in garage/living space wall.
The Following User Says Thank You to Just Bill For This Useful Post:
powder room (09-04-2010)
Old 09-04-2010, 02:01 PM   #3
Thanks for your reply and insite. So you are saying that I need to dig into the concrete, install a drain pump and seal the hole in garage wall. Why do we need to dig a hole in the concrete for? Can we lay the pvc on top of the floor and then connect draining pipe to the pump. What amount of power does the pump need to be? Have I missed anything? Please let me know.
Powder room
cloths washer plumbing height ?? ACE II Plumbing 1 04-20-2010 10:05 PM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 07:10 PM
Washer and Utility sink in a room that has never had plumbing mattreyno Plumbing 1 12-28-2009 09:22 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Relocating a washing machine. Amontoya Plumbing 4 02-28-2007 09:26 PM
