Plumbing Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2012, 10:51 AM   #1
Plumbing Question
I heard some dripping in my basement and went to scope it out. The waste water pipe that goes through my basement floor into the sewer has a leak in it. I think water is escaping between the pipe and the access plate. Should I just try to tighten it down or open the thing up? There's a fair amount of rust so I don't want to make the problem worse.
The water goes between a drip and a steady stream when I use more water.
Any help would be appreciated.
MattRichWarren is offline   Reply With Quote
Old 05-20-2012, 11:44 AM   #2
MarginallyQualified
Rewards Points: 2,464
All good things (eventually) come to an end...
and that includes cast iron sewer pipes.
The leak may be a fitting or it may be that the pipe itself has a crack or worse.
Take some digital pics and post them here.
You may need to only do a small portion to fix the problem...
but often it's far simpler and even less expensive to do more.
The pictures will help to determine where that line is.
The Following User Says Thank You to TarheelTerp For This Useful Post:
ben's plumbing (05-20-2012)
Tags
plumbing , sewer
plumbing career question greaselightning Plumbing 25 06-11-2012 03:30 AM
Help please! New house plumbing question Cdessel Plumbing 1 12-02-2011 11:28 PM
question on grounding plumbing ralfwho Electrical 3 03-02-2011 03:39 PM
Bathroom plumbing question btmtat Plumbing 1 02-20-2011 09:42 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
