Plumbing Problems Newbie Needs Help ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2006, 01:14 PM   #1
Unhappy
plumbing problems newbie needs help ?
our house has a well, the jet pump motor is a 1 hp G.E about 9or 10 yrs old & yesturday it stoped running. it will humm but it wont kick on , my husband filed down the points but that did`nt help we have the pump off right now trying to figure out whats wrong with it any help would be greatly appreciated or amay be a web page that can guide us though figuring out whats wrong , thanks very much
blondewolf is offline   Reply With Quote
Old 08-30-2006, 06:21 PM   #2
electric & plumbing contr
Hard to say without actually seeing it first hand, but I'll do what I can.
If the "hum" is the pump running but not pumping water, then it could be:
-a worn out impeller [replacable, but no snap job]
- no water for it to pull [water level dropped, or simply lost it's prime]
- air getting into intake pipe [broken, loose, cracked, or damaged pipe]
If the "hum" is the motor trying to turn but seized up, then it's probably the bearings. In which case, well...
On a ten year old pump, my advice is to go buy a new one and replace the whole thing while you've got it all apart. run you two or three hundred bucks I'd guess.
Good luck.
Atricaudatus is offline   Reply With Quote
Old 08-30-2006, 06:31 PM   #3
Rewards Points: 530
Does this type of motor have a capacitor? If so, shouldn't it ( they if two) be checked? Just throwing something out there, not sure if this type motor needs the extra boost.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 12:41 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
master bath plumbing problems terri little Plumbing 1 07-12-2007 06:45 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
