Plumbing Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2010, 07:24 AM   #1
plumbing problems
i am in a house with a basement....i have a dishwasher and rarely uses it.....when using the sink to do the dishes, once the water goes down it sometimes leave food in the downstairs bath tub. we have had rotor rooter come in to flush the drain but problem still exists. i have tried flushing with over the counter remedies. nothing seems to work. any suggestions?
nesa1964 is offline   Reply With Quote
Old 05-09-2010, 07:46 AM   #2
You have a partial clog downstream, causing things to back up into the other sink. Surprised Rotorooter did not fix the problerm. They are usually good at that. The problem is after that downstairs drain, so some extensive rooting may be needed.
Old 05-09-2010, 07:54 AM   #3
Using rags as a gasket, force hot water directly from your water heater into the tub drain with a garden hose, but have an assistant check that this water isn't filling up a sink somewhere else in the house.
Run it till you're getting cold water through the hose.
Old 05-11-2010, 12:17 AM   #4
cable the tub drain or from a cleanout that is on the line but upstream of the tub. and stop runnig a bunch of food down your disposal, You will just plug it back up.
plumber Jim is offline   Reply With Quote
Old 05-11-2010, 10:10 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We've had people try to stuff half a leftover turkey pot pie down them....
Food + plumbing system = problems.......
Journeyman Plumber
Old 05-11-2010, 10:13 AM   #6
where did a disposal get in the equation?
The older I get the better I was
possibly huge problems with plumbing - extensive post NowItsShowtime Plumbing 5 04-22-2010 08:37 PM
Fish tank plumbing problems.. Raibaru Plumbing 2 12-15-2009 03:13 PM
Hot Water Plumbing Problems mariyasmth11 Plumbing 1 07-03-2009 10:52 PM
Hot Water Plumbing Problems danielhudson Plumbing 3 07-01-2009 11:07 AM
plumbing problems newbie needs help ? blondewolf Plumbing 2 08-30-2006 07:31 PM
