Old 01-21-2013, 07:11 PM   #1
plumbing problem
okay i have some strange plumbing for my kitchen and laundry room. I have been using the washing machine for over a month now and it has just started to back up into the kitchen sink. any ideas how i can fix it.
the elbow in the corner comes from the laundry.
the black pipe might be an old waste line, but i don't know since the house came with washer and it was hooked up to the white pvc. there is a vent pipe on the roof but it come out above where a cabinet is.
redman88 is online now   Reply With Quote
Old 01-21-2013, 07:15 PM   #2
plumbing problem
Can start by removing the caps and running a snake down the drains and down the open drain for the washer.
Old 01-21-2013, 07:23 PM   #3
plumbing problem
hmmm guess i could go find my snake. and see if i get anything. but i am still confused about the contraption of plumbing behind the washer.
Old 01-21-2013, 07:35 PM   #4
plumbing problem
That is a strange looking bit of plumbing behind the washer. I hope the washer drain line is vented.
Someone who knows much more than me will weigh in soon. I wonder why your pipes go outside like that?
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 01-21-2013, 07:40 PM   #5
plumbing problem
i think that strange bit of plumbing is some kind of vent.
Old 01-21-2013, 08:05 PM   #6
call me E
TheEplumber's Avatar
plumbing problem
IMO it's an attempt at an island/loop vent. You could improve it by removing the plug and installing a studor vent in it's place.
In the mean time- cable the outside line. Sounds like you have a blockage downstream of the sink tie in.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-21-2013)
Old 01-21-2013, 08:08 PM   #7
plumbing problem
well i will have to get a new snake the one i have is for toilets.
Old 01-21-2013, 08:11 PM   #8
plumbing problem
so a studor vent would be a good solution till i can get to remodeling that part of the house and installing a proper vent through the roof?
Old 01-21-2013, 08:17 PM   #9
call me E
plumbing problem
I think so. But if the washing machine is draining fine(without the blockage) then it may not help much.
Old 01-21-2013, 08:19 PM   #10
plumbing problem
i hear it gurgling in the kitchen sink when it is draining.
Old 01-21-2013, 08:32 PM   #11
call me E
plumbing problem
I think your first move is to cable the line as far as you can using a 3/8 cable. After the line drains well without backing up to the sink- you can pull the clean out plug at the top of the loop and run a rinse cycle- see if that cures the gurgle. If so, stick a studor on it
Old 01-21-2013, 08:49 PM   #12
Roofmaster
plumbing problem
Wow! I guess his other job was maker of French Horns.
" A lot of men build things, and a lot of things fall down "
Old 01-21-2013, 09:10 PM   #13
plumbing problem
huh? i am lost.
Old 01-21-2013, 10:08 PM   #14
plumbing problem
huh? i am lost.
LOL, the french horn tubing is bent around like your plumbing
I hope your power outlet next to the laundry drain is on a GFCI circuit that close to the washer - hard to tell from the picture.
profcolli is offline   Reply With Quote
Old 01-21-2013, 10:42 PM   #15
plumbing problem
it it'self is not, but i think its off one of the ones in the kitchen. the electrical in the house needs lots more work. hence why i am planing on remodeling that room and most the rest.
Bathroom plumbing problem Steve Adridge Plumbing 2 11-30-2012 08:35 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
airgap plumbing code problem airgap Plumbing 12 09-15-2009 08:45 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
