-   -   plumbing problem (http://www.diychatroom.com/f7/plumbing-problem-169749/)
redman88 01-21-2013 06:11 PM
plumbing problem
okay i have some strange plumbing for my kitchen and laundry room. I have been using the washing machine for over a month now and it has just started to back up into the kitchen sink. any ideas how i can fix it.
http://i277.photobucket.com/albums/k...982/photo5.jpg
the elbow in the corner comes from the laundry.
http://i277.photobucket.com/albums/k...982/photo3.jpg
http://i277.photobucket.com/albums/k...982/photo2.jpg
the black pipe might be an old waste line, but i don't know since the house came with washer and it was hooked up to the white pvc. there is a vent pipe on the roof but it come out above where a cabinet is.
joecaption 01-21-2013 06:15 PM
Can start by removing the caps and running a snake down the drains and down the open drain for the washer.
redman88 01-21-2013 06:23 PM
hmmm guess i could go find my snake. and see if i get anything. but i am still confused about the contraption of plumbing behind the washer.
dougp23 01-21-2013 06:35 PM
That is a strange looking bit of plumbing behind the washer. I hope the washer drain line is vented.
Someone who knows much more than me will weigh in soon. I wonder why your pipes go outside like that?
redman88 01-21-2013 06:40 PM
i think that strange bit of plumbing is some kind of vent.
TheEplumber 01-21-2013 07:05 PM
199 Attachment(s)
IMO it's an attempt at an island/loop vent. You could improve it by removing the plug and installing a studor vent in it's place.
In the mean time- cable the outside line. Sounds like you have a blockage downstream of the sink tie in.
redman88 01-21-2013 07:08 PM
well i will have to get a new snake the one i have is for toilets.
redman88 01-21-2013 07:11 PM
so a studor vent would be a good solution till i can get to remodeling that part of the house and installing a proper vent through the roof?
TheEplumber 01-21-2013 07:17 PM
199 Attachment(s)
I think so. But if the washing machine is draining fine(without the blockage) then it may not help much.
redman88 01-21-2013 07:19 PM
i hear it gurgling in the kitchen sink when it is draining.
TheEplumber 01-21-2013 07:32 PM
199 Attachment(s)
I think your first move is to cable the line as far as you can using a 3/8 cable. After the line drains well without backing up to the sink- you can pull the clean out plug at the top of the loop and run a rinse cycle- see if that cures the gurgle. If so, stick a studor on it
jagans 01-21-2013 07:49 PM
1 Attachment(s)
Wow! I guess his other job was maker of French Horns.
redman88 01-21-2013 08:10 PM
huh? i am lost.
profcolli 01-21-2013 09:08 PM
Originally Posted by redman88 (Post 1099035)
huh? i am lost.
LOL, the french horn tubing is bent around like your plumbing :wink:
I hope your power outlet next to the laundry drain is on a GFCI circuit that close to the washer - hard to tell from the picture.
redman88 01-21-2013 09:42 PM
it it'self is not, but i think its off one of the ones in the kitchen. the electrical in the house needs lots more work. hence why i am planing on remodeling that room and most the rest.
