Plumbing Pitch - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2010, 09:50 AM   #1
South Jersey
Plumbing pitch
I just got off the phone with my township building inspector about the lawn irrigation system I want to install.
He said the plumbing needs to have a shut off valve, a rain sensor, and it has to be properly pitched and drained. I can handle the valve and rain sensor but what is "pitched" supposed to mean? I'm not installing sewer pipes so nothing really needs to drain other than when I winterize it for the season. For a drain, I was just going to use a 1" to 1/2" tee and just leave a PVC plug in it.
If I have to pitch the pipe how much does it have to be pitched?
I even have to have an electrical inspection for the low voltage wiring for the valves... wtf.
Reddhead is offline   Reply With Quote
Old 08-24-2010, 10:42 AM   #2
Rewards Points: 150
i am surprised he does not want a back flow prevent-er.it would be impossible to drain a sprinkler by gravity.maybe he meant having some way to blow the lines out using air pressure to winterize,
rudolph58 is offline   Reply With Quote
Old 08-24-2010, 12:24 PM   #3
South Jersey
Sorry, I forgot to mention that he does want a backflow device but he didn't particularly care what kind and that it didn't need to be tested. Most installers here use PVB
I talked to a licensed plumber here at my work and he said to just put a drain fitting in anywhere I have a low spot in my supply line.
Old 08-24-2010, 12:32 PM   #4
South Jersey
And just to add to the absurdity, my Mother lives in the same town as I and she had an installer with 20 years experience install her system, and none of it was ever inspected unless he greased the right palms.
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 09:55 AM
Roofing MINIMUM pitch? ControlTech Roofing/Siding 1 11-26-2009 10:10 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
