Plumbing Not Lining Up - Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2013, 11:48 PM   #1
Rewards Points: 892
Plumbing not lining up - help
My plumbing under my new vanity doesn't line up. What do I need to make the connection? Thanks
Daugela is offline   Reply With Quote
Old 08-17-2013, 12:00 AM   #2
A couple of 22.5 or a 45 right off the pipe coming of the wall. Then adjust the P trap accordingly.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plummen (08-17-2013)
Old 08-17-2013, 09:41 AM   #3
Rewards Points: 892
Ok, but are there adapters to attach that trap to the pipe coming from the sink. They're two different sizes.
Old 08-17-2013, 09:54 AM   #4
PoleCat's Avatar
Rewards Points: 1,646
One is for a 1 1/2 tail piece, the other for a 1 1/4 tailpiece. Bathroom sink is going to be 1 1/4.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Daugela (08-18-2013)
Old 08-17-2013, 06:22 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Use the1-1/2" by 1-1/4" reducing washer,its the one right next to the abs nut .
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Old 08-21-2013, 10:17 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 990
Anything other than what what VIP posted will not be a proper installation.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-21-2013, 10:32 PM   #7
DIY staff
Rewards Points: 7,174
Look up--Ram Bit---that is a drill operated cutter that will allow you to cut out the old pipe from the T-fitting in the wall so you can use a street 45 or 22.5 in the T.
1st-time home buyer novice plumbing renovation question dakotajoe Plumbing 6 06-28-2011 12:50 PM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 10:12 PM
moisture under slab, roughed-in plumbing bergerdude Building & Construction 4 03-25-2011 09:29 PM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 08:55 PM
