-   -   Plumbing not lining up - help (http://www.diychatroom.com/f7/plumbing-not-lining-up-help-185402/)
Daugela 08-16-2013 10:48 PM
My plumbing under my new vanity doesn't line up. What do I need to make the connection? Thanks
http://i925.photobucket.com/albums/a...psabaa7ab1.jpg
VIPlumber 08-16-2013 11:00 PM
A couple of 22.5 or a 45 right off the pipe coming of the wall. Then adjust the P trap accordingly.
Daugela 08-17-2013 08:41 AM
Ok, but are there adapters to attach that trap to the pipe coming from the sink. They're two different sizes.
PoleCat 08-17-2013 08:54 AM
One is for a 1 1/2 tail piece, the other for a 1 1/4 tailpiece. Bathroom sink is going to be 1 1/4.
plummen 08-17-2013 05:22 PM
Use the1-1/2" by 1-1/4" reducing washer,its the one right next to the abs nut .:)
Javiles 08-21-2013 09:17 PM
Anything other than what what VIP posted will not be a proper installation. :whistling2:
oh'mike 08-21-2013 09:32 PM
Look up--Ram Bit---that is a drill operated cutter that will allow you to cut out the old pipe from the T-fitting in the wall so you can use a street 45 or 22.5 in the T.
