Plumbing Newb, Leaky Tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2009, 05:16 PM   #1
I have a bathtub/shower faucet that leaks. It's a three handle tub.
In addition to this it has some water that comes out of the faucet when the shower head is "on".
Lastly, if the water is on a slow flow rate (to conserve water while showering) it can make an awful rattling like noise. It sounds like the pipes within the wall are vibrating. Any idea what this could be?
Also, I assume I need to replace the stems and seats for the hot and cold water handles. In order to remove the seats I need to turn off the water to the house. I don't have a basement (1970s home in TX). Where would I find the cutoff valve? I think it's in a hole in the front yard near the fire hydrant.
After I turn the water off do I need to open the tub faucets (hot and cold) to drain them so I can remove the seats? Do I need to turn off my hot water heater first?
I'm a total plumbing newb, but want to learn!
Much thanks in advance!!
gr7070 is offline   Reply With Quote
Old 06-22-2009, 06:40 PM   #2
Joe F's Avatar
Rewards Points: 294
There should be a shutoff in the house, but if you can't find it turning it off at the street will work. I'm guessing that replacing the washers and seats will solve all of the "ills". The stems will probably be OK. I'd bet that the vibration you hear is from a loose or worn washer shuttling back and forth. Oh, no need to drain the water heater.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 06-24-2009, 04:40 PM   #3
drain the water heater? i don't think that's necessary. water doesn't flow out of the water heater unless you have water pressure.
freewheel is offline   Reply With Quote
leaky bathroom faucet; how do I change washer yummy mummy Plumbing 21 01-28-2012 01:13 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 09:55 PM
Quick leaky faucet question JPfixit Plumbing 5 12-09-2008 11:21 AM
