Plumbing A New Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2008, 01:44 PM   #1
plumbing a new sink
Can someone tell me what a studor vent is? Is this a standard plumbing part for a sink installation?
Can you confirm that shutoffs and pvc are standard parts for plumbing a sink.
Existing unutilized plumbing (water and drainage) for an old claw foot tub was utilized for plumbing our new sink.
Thanks,
Karen
kchiasson is offline   Reply With Quote
Old 09-23-2008, 03:04 PM   #2
Registered User
Termite's Avatar
Hi Karen.
A studor vent is an Air Admittance Vent/Valve, or AAV. Typically and ideally, plumbing fixtures have a vent pipe in the wall that goes all the way to the roof, and that pipe serves to allow air into the pipes to facilitate water flow...Just like holding your finger on a soda straw full of water, an unvented drain doesn't drain. When you remove your finger from the straw...Or vent the fixture...The water runs down.
In certain circumstances, plumbers can't run vent pipes for sinks, showers, and other fixtures. That's usually because the vent pipe is impractical, such as on a kitchen island. That's when an AAV is used. The AAV is installed downstream from the trap in the wall or in a cabinet. It has a one-way valve in it that allows the drain to pull air in through the AAV, but it won't let sewer gas escape.
Chances are, your old tub was vented. If the sink isn't draining, there's a chance that it was hooked up incorrectly or it isn't venting for some reason. You can certainly install an AAV between the sink's trap and the wall. The AAV needs to be above the drain level of the sink in most cases, glued to a vertical piece of PVC.
Describe the problem, if there is one.
Here's a Studor AAV
Need Help Plumbing A Utility Sink... drummereef Plumbing 17 07-29-2008 03:16 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 12:25 PM
PLEASE HELP..Kitchen Sink Plumbing!! davo420 Plumbing 6 02-28-2006 06:37 AM
