-   -   Plumbing for new shower kit question (http://www.diychatroom.com/f7/plumbing-new-shower-kit-question-173418/)
noviceshock 03-02-2013 05:11 PM
HEllo everyone
I am in the process of installing a new shower in my bathroom. I am replacing an old cast iron tube with a shower only. The shower is 42 X 34. I have two question I was wondering if I can get some help with.
1.) I am installing a Delta 132900 shower head and hardware. My question is about the fittings from the valve to the supply lines. I was told the fiting s should be copper from the vale at a minimum but can transition to cpvc . Please look at the picture and see this looks ok. Do I need to put teflo tape on the threads or can I just tighten.
http://i151.photobucket.com/albums/s...ps55e143bc.jpg
Second question
I know I need to move the support for the shower head up but my question is how far do I set it back from the face of the studs?
My shower kit is a Sterling Ensemble 4 piece kit.
http://i151.photobucket.com/albums/s...psd4d13f16.jpg
Ghostmaker 03-02-2013 05:20 PM
Are you using proper CPVC to Copper adaptors? Can't tell from your photo.
noviceshock 03-02-2013 05:26 PM
YEs the fittings screwed into the valve intake for hot cold and the discharge to the shower head are all cooper to cpvc fittings.
djlandkpl 03-02-2013 05:51 PM
Originally Posted by noviceshock (Post 1128426)
Second question
Set it so the threads are just behind the back of the drywall.
TheEplumber 03-02-2013 05:55 PM
199 Attachment(s)
Use teflon tape, pipe dope, or both to seal the threads.
For the shower head- I set them back so it's flush with the stud face- or further.
I also set it above the fiberglass so it's high and don't have to drill the panel- allow room for the trim ring above the panel.
noviceshock 03-02-2013 05:55 PM
Thank you
Ghostmaker 03-02-2013 08:11 PM
Put your shower head backer board direct behind the winged ell and fasten the ell to the wood with wood screws..
