-   -   Plumbing mystery? (http://www.diychatroom.com/f7/plumbing-mystery-172701/)
TinyAvenger 02-23-2013 01:47 AM
Plumbing mystery?
My home was built in 1960 and has cast iron pipes. About every 2 months our toilet backs up and we have to call someone out to snake the pipes. We have had 2 different plumbers run a camera through the pipes and neither found any collapse or holes. They both told us to use cheap toilet paper that breaks down easily like Scotts, which we now do, but the problem persists. Here are some basic facts:
1. House built 1960
2. Cast iron pipes
3. Ground floor toilet
4. If you flush and the bathtub gurgles you can expect a flood within 24hrs.
5. Did my own little non-scientific test which consisted of dying a piece of toilet paper bright red with food coloring and sending my husband to the clean out to see if it came through or caught under the house. He says he saw it come through but now, just a few days later, it's backing up again. There is no water standing in the clean out, so I assume the problem is under the house.
Can anyone help me diagnose what 2 plumbers can't seem to? I'm wondering if it might be the ventilation stack. Thanks in advance.
64pvolvo1800 02-23-2013 05:51 AM
1. House built 1960
2. Cast iron pipes
How far down do they snake to clear the problem?maybe the problem isn't yours?
Justins1171 02-23-2013 06:20 AM
I had a similar problem with my house, except my house was built in 2006. In order to fix the problem I needed to snake the ventilation stack. What you can also try before you invest in a plumber doing that, because its usually a two man job is to snake the line coming off your kitchen. If you don't have a snake, I'd suggest going to a big box store and getting a 25 ft auger. It's saved me so much money in the long run having it around the house. All your plumbing connects in the house and you have the one main line that comes off the house to the city's line, that's where your clean out is... Along the main line connecting to the city's.
joecaption 02-23-2013 07:31 AM
City sewer or septic tank?
