Plumbing Mystery - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2011, 11:25 PM   #1
Plumbing mystery
The previous owners of my house dropped the ceiling in my kitchen to accommodate plumbing for an upstairs bathroom. I'm in the process of remodeling my kitchen and am planning on running the waste and supply lines through the joists in order to restore the ceiling to its original height.
I'm trying to make sense of the way the waste lines are currently set up -- see the attached pic. The line from the sink runs diagonally for 5 ft before joining up with the main waste arm. Why do this, rather than run a much shorter arm perpendicular and into the waste arm (see blue line)?
For context, the picture is taken from below looking up at the kitchen ceiling.
iconnary is offline   Reply With Quote
Old 07-07-2011, 11:33 PM   #2
Could be because the entire run is vented by one vent and the rest is wet vented, therefore the toilet has to be the last to drain to the line before the stack.
You might want to re-think drilling the joists with the drains running like that. Any mistakes and you could affect their integrity.
VIPlumber is offline   Reply With Quote
Old 07-07-2011, 11:44 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I second ALL of this. What size are the joists? I'm assuming they are dimensional lumber?
There are only certain places you can drill dimensional lumber. There is a reason they ran it below the joists. Your other option is to completely replumb the underside of your house as well and get it to where your drains run parallel with the joists. How low is the ceiling?
Journeyman Plumber
Old 07-08-2011, 12:28 AM   #4
The joists are dimensional lumber, 2x10 (9.25"). My reading tells me that I can put holes no larger than 25% of the depth through the centerline of the joist. That gives me 2.3" max diameter holes I can put through the joists, which ought to accommodate 2" waste line for bath and sink. The toilet line is 3" but will only need to run through two joists, one of which is sistered, as will the other be.
As for venting, so far as I can tell the main waste line shown in the pic isn't vented itself, but rather goes straight into the house's main vertical sewer line. The main sewer line is vented. This seems contrary to my understanding of when/where venting is needed, but we've never had any issues with the plumbing setup as is.
Old 07-08-2011, 10:25 AM   #5
Doing it myself
Alan's Avatar
You usually will need a hole about 2-9/16 for 2" which is greater than 2.3" .
There's also the issue of maintaining grade if you have to drill on the centerline of the joist.
Journeyman Plumber
Dishwasher plumbing mystery Handy Cathi Plumbing 3 07-01-2011 10:19 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
can anyone identify this mystery basement plumbing??? pkovo Plumbing 6 03-08-2009 11:20 PM
