Plumbing Multiple Shower Heads - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2013, 07:07 AM   #1
Hi all,
I am installing a new master bath in my house and I have a couple of shower questions that I can not find consistent answers to online.
I am planning on 3 heads...a normal shower head, an overhead "rain" head and a hand held wand mounted on a side wall.
I have a delta r10000 universal valve and a delta r11000 3/6 rough diverter.
I understand that the mixer feeds theee diverter, and that the diverter can then feed three heads. The diverter can be used with a 3 setting or a 6 setting selector trim, the cartridge comes with the trim. We would go with the 6 setting which will allow any head to be used individually or any 2 used together.
The pieces came with 1/2" inlets, is this adequate? should i try to find a company that has 3/4". We are not using body sprays.
Do I need a pressure balancing loop in this situation? If so, does anyone have a diagram of this?
I am not new to installing showers...but have never done multiple heads.
Has anyone worked with these Delta models before? any hints/tricks?
Thanks.
terpjr is offline   Reply With Quote
Old 07-15-2013, 05:39 PM   #2
Rewards Points: 1,864
If you read the installation instruction them may have a drawing on how they recommend you plumb it.
Old 07-15-2013, 07:30 PM   #3
Bill Kearney
Rewards Points: 1,174
Having had a similar kind of setup in our old house I'll recommend using 3/4". The old stuff was 1/2" and when I had an added hand-shower to the existing wall shower there wasn't a decent enough flow. When I remodeled the space I went with 3/4" for both the hot and cold (the main supply was, thankfully, close enough to make this possible). This supported being able to run two rain heads and a handshower... all at the same time with the same pressure as just one running. We went with Hansgrohe for this as they were one of the few vendors that offered a 3/4" system with the necessary number of outputs.
Start by finding out how much water pressure you've got. And how close a 3/4" source is for the hot & cold water. Otherwise you may be disappointed with how the rain head works...
wkearney99 is offline   Reply With Quote
Shower plumbing access necessary? boogie81 Plumbing 4 03-25-2013 09:02 PM
Plumbing for shower and steam generator Smitny22 Plumbing 10 02-20-2012 05:19 PM
Need help. 1 shower faucet for 2 shower heads? Downshift93 Plumbing 4 11-08-2011 09:43 AM
Add shower plumbing to an existing bathtub Clock72 Plumbing 9 06-11-2011 04:23 PM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 08:26 AM
