Prev Previous Post   Next Post Next
Old 10-03-2009, 03:43 PM   #1
Default plumbing leak or pipe sweat?
i have a very strange thing going on:
directly underneath the return pipe coming out of the hallway radiator, in the basement ceiling, the floor sheathing is all water stained, and actually has been wet to the touch for weeks. the area of staining and wetness is definitely spreading.
upon close examination of the only fitting there (a standard 90º elbow, then pipe going through a hole in the floor) i can't find any trace of wetness or signs of leakage. the oak floor above is totally dry (but is definitely heaving/rolling up due to water coming from somewhere. the fitting is green and funky looking, which looks like just regular flux "ooze," or something.
i was just about to cut out the 90 and sweat another one on, but it's a lot of work and a very tight spot so thought i'd ask you guys first.
when i bought the house the stains were there, but it's gotten much worse.
i guess it couldn't hurt to sweat another 90 on? maybe there is some sort of pinhole leak on the pipe itself inside the flooring? there's no reason i can see that the pipe would be sweating there. it's always dry when i touch it, both above and below the floor.
what gives?
thanks.
schmolze is offline   Reply With Quote
More On This Topic
Here's how to dance and have fun at a club, without getting yourself kicked out. Read More »
The number one thing to think about before you start drying your books is what, wet them. You never ever want to put yourself in a situation where you are potentially contaminating yourself or household or your family in order to save some material... Read More »
How to Cut Copper Pipes
How to Cut Copper Pipes by Expert Village
Hey good people, I'm back with Expert Village and I'm Don Golden. We are talking about copper pipes and how to sweat them, cut them, and put them together so they can hold water. I have got a length of pipe right here and pipes are pretty standard. You... Read More »
How to Dry Fit Copper Pipes
How to Dry Fit Copper Pipes by Expert Village
Hey everybody Don Golden here with Expert Village. We are talking about copper piping and copper fitting. We have prepped these two little demo pieces and the 90 degree union that I am going to show you how to sweat shortly but I got a little ahead of... Read More »
Alcohol Use & Menopause
Alcohol Use & Menopause by Expert Village
Hello there my name is Dr. Susan Jewell. And in this clip we’re going to talk about the alcohol effect when you are in menopause. My basic recommendation and I think any medical professional is not to drink alcohol at all. But if you’re going... Read More »
How To Solder Copper Pipes thekctermite How To Guides 65 11-04-2009 10:14 AM
AC Coil drain pipe questions fritzycat1 HVAC 10 09-11-2009 05:20 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-22-2008 01:48 AM
PVC pipe leak JohnJak Plumbing 2 07-08-2008 10:27 AM
Clueless on a/c leak trouble notmrfixit HVAC 3 07-06-2008 11:33 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
