Plumbing Leak!!!! Arh!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2012, 10:39 PM   #16
also whats the best way to cut the drywall
jsteezy1290 is offline   Reply With Quote
Old 04-06-2012, 09:13 AM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Ok, if someone told you NOT to use putty on the fiberglass, and you didn't put anything in there, then i'd bet it IS your drain that is leaking. Go ahead and use putty on it, and afterwards, slap whoever told you not to.
Journeyman Plumber
Old 04-07-2012, 11:37 AM   #18
Originally Posted by jsteezy1290
isnt there subflooring above my ceiling? i really dont want to cut into all that if i dont have to .. i was wondering if i cut a acess panel in the closet to have a look at the faucet and shower pipes to see if there leaking? also the leak must be little because the spot was dry this morning.
My thought is that you will likely have to repair the ceiling downstairs. If you cut out the damaged area, you might be lucky and find that you have a plank subfloor instead if plywood. If so , then it would be easier to try and track the path of the leak to it's source. If as posted above, it's easier to cut open the closet wall to see under the tub then do that. If you can get hold of an inspection camera, that will help you. Once you have a visual under the tub, look for staining on the subfloor or mineral deposits on protruding bits on the tub. Maybe puff some flour or durabond powder under it and then run the water and the jets and see what happens.
Evstarr is offline   Reply With Quote
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Crawl space gas leak WillK Plumbing 13 10-19-2010 09:58 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Questions about fixing a drain leak and running plumbing CAD Plumbing 3 10-24-2009 04:28 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
