Plumbing Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2013, 04:28 PM   #1
plumbing leak
Hi,
The 3/4 inch copper line running up from my basement floor and into the gate valve shut off is causing a problem because as the pipe enters my street side inlet on my meter there is a small leak where the nut is connected to the meter. I need to turn the water off at street side so I can take this nut off but the gate valve keeps turning and turning and nothing happens. It won't shut off the water. I went outside to the water shut off and turned the handles and there is still water flow. I don't understand.
mmiller is offline   Reply With Quote
Old 04-09-2013, 04:34 PM   #2
Rewards Points: 13,750
Very common for a gate valve to fail, it's needs to be replaced anyway with a ball valve.
If the city side valve will not shut off I'd be calling them to come fix it.
Old 04-09-2013, 04:43 PM   #3
the outside valve turns but still wont cut the water off. Its such a tight area I have no idea how im going to remove the gate and replace with a ball valve. If I post a picture can you see what im talking about?
Old 04-09-2013, 05:27 PM   #4
Rewards Points: 286
Agree with Joe, call the city first before you do anything, it should be their responsibility.
jmon is offline   Reply With Quote
Old 04-09-2013, 05:43 PM   #5
Originally Posted by jmon View Post
Agree with Joe, call the city first, it should be their responsibilty.
What about the inside of the house though on the street side with the stuff off issue?
Old 04-09-2013, 06:37 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 684
The city should have a curb stop- at least they do in my area. They need to turn that valve off, then you make the repairs on your valve.
Old 04-09-2013, 07:38 PM   #7
There is a ball lever outside my house at the meter though. Shouldn't that shut the water off to the house. I turned it perpendicular to the pipe and nothing happened.
Old 04-09-2013, 07:47 PM   #8
Plumber
Rewards Points: 684
I thought the meter was in your house? If it's out side and that is where the leak is- call the city. It is probably their meter and leak
Old 04-09-2013, 08:41 PM   #9
BIGRED
Rewards Points: 252
Make sure you are working on the water meter and not the Gas meter. The Gas meter is probably outside and the water meter should be inside to prevent it from freezing. Your water service from the city should be coming up through the basement floor or very low on the basement wall for the same reason - freeze protection.
I agree with all these guys, before you worry about cracking meter nuts call the city water department and have them make sure the buffalo box at the street turns off your home water FIRST or get a licensed plumber to check it out as they should have the required access also and they can usually fix a drip at the meter without cracking the meter nuts.
Grampa Bud is offline   Reply With Quote
Old 04-09-2013, 09:08 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
Man you guys up north really complicate things with all your snow and stuff, ooops did i mention it was 82 today.. Sorry.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-09-2013, 09:13 PM   #11
Plumber
Rewards Points: 684
LOL, my 52 and sunny was just right..... anything over 75 is too hot
Old 04-09-2013, 09:18 PM   #12
The leak is in the basement as the copper pipe comes up from the basement floor and into the meter on the inlet and I can't fix the leak until I can shut off the water supply but the gate valve is not working its keep going around and around not shutting anything off. Outside of the house I see another shut off I am assuming that is for the water. Its a ball valve. I turned it and it didn't shut the water off. Why do you think this is?
Old 04-09-2013, 09:21 PM   #13
I know the difference between a gas and water meter. If there is a leak on the street side of the meter in the basement am I still responsible for that. Its a ball valve. Its not working correctly so I can't even shut the water off to take a look at the small leak coming from the nut that is connected to the inlet of the meter.
Old 04-09-2013, 09:21 PM   #14
Master Plumber
Javiles's Avatar
Rewards Points: 996
LOL the only thing i like at 52 and lower are my coronas.
Old 04-09-2013, 09:35 PM   #15
Rewards Points: 286
Just a suggestion, it's best to call your city water department first to see who is responsible for it. Every municipality is a little different when it comes to this area. I don't know for sure who is responsible in your case. However, from what you describe it seems like the city should be, they usually own the water meter. I can only speak of my similar situation, called my village water department and they came out and took care of everything at no cost.
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 03:34 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 07:46 PM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Questions about fixing a drain leak and running plumbing CAD Plumbing 3 10-24-2009 04:28 AM
