Plumbing Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2012, 04:08 PM   #1
plumbing leak
hello i have a leak at the very bottom of a secondary drainage stack right at the basement foor level is there any way to repair this without breaking up the floor and replacing the coupling have tried an epoxy putty but it still leaks
thanks
gerjon22 is offline   Reply With Quote
Old 08-11-2012, 04:10 PM   #2
DIY staff
Rewards Points: 7,174
Sorry,need more info and pictures if possible.
What kind of pipe?
Can you see the coupling?
Old 08-11-2012, 06:42 PM   #3
Rewards Points: 13,750
Cast iron, PVC, ABS?
Old 08-11-2012, 07:17 PM   #4
Rewards Points: 582
thanks
as already mentioned pictures are worth a 1000 words.....well in your case an answer to your question
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Crawl space gas leak WillK Plumbing 13 10-19-2010 09:58 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Questions about fixing a drain leak and running plumbing CAD Plumbing 3 10-24-2009 04:28 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
