Plumbing Kitchen Sink On Outside Wall In Cold Weather Climate (MN) - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2010, 02:32 PM   #1
Plumbing Kitchen Sink on Outside wall in Cold Weather Climate (MN)
Hello,
I am remodeling my kitchen, and I currently have my hot and cold water lines coming out of the floor inside my kitchen (about 6" from the wall). The pipes are coming up from my unfinished basement. I would like to move the pipes to the inside of the outside wall, so they can come out of the back of my cabinets, instead of coming out of the floor or my cabinets. But I am worried about the pipes freezing, and was wondering if there is anything I can do to prevent that from happening. Also note, there is a HVAC vent in the exact area where my plumbing is. Will insulating the wall along with the heater be enough, or should I just deal with them coming out of the floor?
Thanks!
tpthaler is offline   Reply With Quote
Old 04-14-2010, 03:04 PM   #2
We always come out of the floor when the sink is on an outside wall. If you put them in the wall you will have them freeze on you at some point.
plumber Jim is offline   Reply With Quote
Old 04-15-2010, 06:20 AM   #3
Yep, never in the outside wall in your climate. Even here in the balmy mid atlantic, we have outside wall plumbing freeze on occasion.
Old 04-15-2010, 07:18 AM   #4
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I had to move some from the outside wall to the floor. The owner had used heat cord to keep them from freezing. Just leave them in the floor and work that into your new design. Outside walls get way to cold around here for pipes to run through them.
Big N8 is offline   Reply With Quote
Old 04-15-2010, 07:36 AM   #5
Military Mom of 4
Snav's Avatar
If you just don't want to *see* them then you can bring them up from the floor and build a concealment box of some type - out of furring strips (paint it) - so at least the concealment will blend in and look a bit more aesthetically appealing.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Kitchen, sink, plumbing ?'s Canada 83trekker Plumbing 3 01-10-2010 01:31 PM
Simple Wall Mount For Vessel Sink DeanVesuvio Kitchen & Bath Remodeling 2 12-31-2009 08:28 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
