Plumbing Job Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-07-2010, 09:57 AM   #1
I just got hired by a small plumbing company But I'm not even a registered apprentice yet they have me doing small stuff like installing sinks fixing toliets taking apart ptraps they send me out alone do you need a licence for doing stuff like this even though im not alterating the plumbing system. I just dont want to get in trouble by the "plumbing police" thanks
Bigd3129 is offline   Reply With Quote
Old 08-07-2010, 09:58 AM   #2
Where are you located ?
Old 08-07-2010, 10:00 AM   #3
In ontario, canada
Old 08-07-2010, 10:40 AM   #4
fabrk8r
fabrk8r's Avatar
Bigd3129,
Go here: http://www.plumbingzone.com/?gclid=C...FRUd5wodkDnPaA
Let them know your concerns. There are very knowledgeable plumbers there who will help you out.
Good luck!
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-07-2010, 10:48 AM   #5
the Musigician
DangerMouse's Avatar
Ummmm, aren't those all things homeowners can do themselves without permit, therefore perfectly OK for HIM to do as well?
Po)
DM
Old 08-07-2010, 10:55 AM   #6
fabrk8r
fabrk8r's Avatar
As licensed HVAC tech/Sheet Metal Journeyman who works for a plumbing and heating business, I know that it is illegal in my area (Iowa) for an unlicensed plumber or HVAC tech to work alone in the field.
I believe that this applies to most locations in the US and Canada.
With that being said, I know it still occurs frequently with few repercussions for the offenders.
Old 08-07-2010, 10:57 AM   #7
Po)
DM
Homeowner can't do plumbing in MA
Not sure of other states
Old 08-07-2010, 10:57 AM   #8
fabrk8r
fabrk8r's Avatar
Po)
DM
If he's doing it in his own home, its okay, like SD said, if its allowed for homeowners to do their own plumbing in his locality.
The laws were established to protect the workers as well as home owners and business owners.
Old 08-07-2010, 11:11 AM   #9
the Musigician
At our old place, when I swapped out the vanity and toilet, they told me as long as I wasn't changing any lines or drains, I did not need a permit. I assume it'd be the same for removing a P-trap to clean a drain out. However, as stated, these are things the HOMEOWNER can do, but maybe not the OP in that area in this circumstance.
DM
Old 08-07-2010, 11:37 AM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 436
If you plan to make plumbing a career, do yourself a favor and get registered with the plumbing board (or whatever your area calls it) You need a certain amount of on the job (OJT) hours to qualify as a journeyman. Start documenting them now, not later.
Your employer is probably taking more risk than you are. You should be registered and directly supervised. I can only tell you what my area requires. Its best for you to get in touch with your labor board and ask some "what if" questions. Don't rely on co workers opinions. My two cents
Old 08-07-2010, 12:04 PM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Po)
DM
Around here it's the difference between doing it yourself, and doing it for someone else and getting paid for it.
If you are billing a customer for plumbing work that you are doing, you should either be a licenced plumber, or a legitimate apprentice working under a journeyman who's shop is going through a training agent program.
If I were to be working illegitimately while trying to get into the apprenticeship, I could be kicked out and not allowed to work in the state ever again as a plumber.
Not sure what Canada's laws are.
Journeyman Plumber
Old 08-07-2010, 12:07 PM   #12
Licensed Master Plumber
Apprentices can not work unless directly supervised. That means that when it's coffee time, you either have to be the gofer or sit and wait until your master gets back. No, you can do absolutely nothing plumbing related without direct supervision. You can sweep floors, pick up tools and wash the truck. Your boss is putting his license and your career at risk.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 08-07-2010, 01:02 PM   #13
Plumber
Rewards Points: 436
We try not to tell our apprentices about coffee breaks. Let them figure it out on their own - part of the learning process.
Old 08-09-2010, 01:56 AM   #14
If you're working in your own house, that's fine. If you're getting paid to work in someone else's house, then it's not.
Sounds like your boss is either trying to charge the client for an apprentice ~$15/hr and pay you what, $10-12/hr? Or you just started working for him and are on a probationary trial. Has he ever mentioned an apprenticeship to you? Get registered so you can get credit for hours worked.
I've worked for a few shady ones over the years, screwing both their customers and employees. Kinda leaves a bad taste, ya know what I mean?
VIPlumber is offline   Reply With Quote
Question about plumbing project tx_kewlgurl Plumbing 1 01-09-2010 08:49 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
