Old 10-25-2009, 09:41 PM   #1
Default Plumbing Help for installing RO Unit and Dishwasher
Good Day,
I need to install a Reverse Osmosis Unit and also will be installing a Dishwasher next to the sink.
When I run lines for the Dishwasher, can I just tie into the existing lines (I have cold,hot and drinking water lines already under the sink)...or do I have to run new lines to the dishwasher unit from downstairs?
Would you put the RO filters and storage tank under the sink, or better downstairs?
Thanks!
hellothere123 is offline   Reply With Quote
Old 10-25-2009, 09:50 PM   #2
Master Plumber/Mechanical
Each of the appliances shold come with install instructions..just follow them
It will perfectly right to make supply water connections under the sink and not the downstairs sink. Same with dishwasher drain connection
You can also place the RO system under the same sink
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
More On This Topic
Hi! I'm Cathi Pare with the City of Santa Barbara Water Resources speaking to you today for expertvillage.com. We were checking for leaks and we determined that it wasn't in the supply line outside so we are now starting in the kitchen. We are looking... Read More »
Whether you're remodeling a kitchen or you have a broken dishwasher, installing a new one can be fairly easy and completed in less than one day. A new dishwasher has been known to make hectic lives easier, because you can start it and leave it to do its... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
Hi my name is Tony and I work for Stanford Blood Center. Today, I will discuss how we process our blood. First, when we receive the blood here, it comes in these coolers. Different kinds of coolers come from different areas. Here we have a tag which... Read More »
How to Seal a Sink
How to Seal a Sink by Expert Village
I’m Lee. I have a degree in architecture and about ten years construction experience. We just installed a sink from, probably from the fifties, into a house from the seventies. And what we want to do is seal everything up around the drain pipes and... Read More »
Thinking about installing a dishwasher kossuth Appliances 1 09-23-2009 12:05 PM
conversion of portable dishwasher to stationary one grimsbyman Plumbing 6 07-12-2009 10:10 PM
Dishwasher Seems Never To Stop Running whitedavidp Appliances 12 07-01-2009 11:16 PM
Dishwasher installation Andy Griffith General Discussion 3 03-02-2009 08:06 AM
Dishwasher Leaves Food On Dishes BigJimmy Appliances 5 03-26-2008 04:44 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
