Old 02-17-2012, 01:39 PM   #1
Plumbing fixtures
How can I tell if I'm buying a good quality fixture (like a faucet set) or a cheap "plastic" one that may last a year or two?
Rick48 is offline   Reply With Quote
Old 02-17-2012, 02:58 PM   #2
Plumbing fixtures
First pick it up, the weight ought to tell you if it is plastic or brass. Stay away from big box store house brands. I try to stick with Delta's and Moen's.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
plummen (02-18-2012)
Old 02-17-2012, 07:08 PM   #3
Plumbing fixtures
delta and moen are good choices always make sure it has the brass pop up assy...thats the better choice over plastic...
Old 02-17-2012, 11:29 PM   #4
Plumbing fixtures
also be careful buying delta and moen at box stores they make to grades for them if it is only sold exclusive for the box store that is a good red flag indicator. do not know much about moen any more but if you are looking at delta and it says it has a multi choice valve that is the better delta valve body for a tub shower valve
jaydevries is offline   Reply With Quote
Old 02-18-2012, 08:30 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Plumbing fixtures
Ive had no problems with the moen faucets ive bought at menards with plastic pop ups,and ive bought lots of them.
only time I use the metal/brass pop ups is on commercial jobs where theyre required around here
Definately stay away from the cheap off brands
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
plumberinlaw (02-19-2012)
Venting of basement plumbing fixtures david.plymouth Plumbing 3 01-18-2010 06:46 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sediment in fixtures from Plumbing N01B4ME Plumbing 3 09-18-2009 11:25 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 05:08 PM
