Plumbing, Electrical - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2011, 10:37 PM   #1
Wink
plumbing, electrical
hi i have a boiler with two pumps. one pump, has 2 zone valves and the other pump workes directly through the relay box. basically i have three thermostats in this boiler. lately the boiler started making me problems the pump might work and the boiler wont turn on or sometimes the boiler would work and not stop even the thermostats were suppose to shut of the boiler, zone valve, or the pump. what can be the problem is it a pluming problem or electrical problem?
bsirota is offline   Reply With Quote
Old 09-09-2011, 07:45 AM   #2
Generally, the thermostat calls for heat and starts the pump circulating water. The temp drops at the heater and the heater fires up. Sometimes the two functions are not directly connected, often they are. With the thermostat being connected(thru a relay) to the pump and to the heater fuel valve. If it works sometimes, check for loose wiring connections.
Old 09-09-2011, 09:04 AM   #3
Plumb or Die!
A boiler running wild is an excellent time to call a service technician.
plumber666 is offline   Reply With Quote
Old 09-09-2011, 02:43 PM   #4
thanks a mil i will check for loose wires
Old 09-10-2011, 08:33 AM   #5
Rewards Points: 1,214
Does your boiler also make domestic hot water for your house??
COLDIRON is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 09:55 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 08:46 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
