Plumbing Drain Line Access When Finishing Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2013, 08:08 AM   #1
Plumbing drain line access when finishing basement
I am having my basement finished and am getting very different advice from the two companies I'm considering. The main 4" PVC drain line exits through the front wall of the basement. There is an access cap on the line right where it meets the wall at about 6 feet up from the floor. There is another access cap to the same line in the front yard.
I am concerned about maintaining access to this line/cap once the basement is finished. Company A says "don't worry about it, you don't need access to it from the basement, if needed the plumber would gain access through the cap in the front yard." Company B says make sure to leave it accessible, either inside a cabinet or with access through or around the sheetrock."
Who is right?
bartlejo is offline   Reply With Quote
Old 10-04-2013, 08:56 AM   #2
Master Plumber
Benplumbing's Avatar
I would definitely leave an access to that clean out plug. Granted that if your sewer were to back up many service man would not use that to clean out your sewer. opening that plug when the sewers backing up would create a giant mess trying to catch all the water. Most of us would pop a toilet on the first floor to gain access. Given all that it is still an access to your sewer that should be left accessible!
Benplumbing is offline   Reply With Quote
The Following 2 Users Say Thank You to Benplumbing For This Useful Post:
plummen (10-05-2013), TheEplumber (10-04-2013)
Old 10-04-2013, 09:13 AM   #3
There are nice-looking access doors with pop-off panels that install easily.
RoyalAcresRod is offline   Reply With Quote
connecting clawfoot tub to existing drain line in concrete basement michaelflinn Plumbing 0 07-02-2012 04:48 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 08:36 PM
basement bathroom (concrete floor drain plumbing) amakarevic Plumbing 4 11-27-2007 05:37 AM
