Old 06-01-2012, 09:53 AM   #1
MikeRichardd's Avatar
Plumbing and drain
Is it acceptable to have the hot and cold pipes touching one another?
Can I install the tub drain on an angle?
Plumbing and drain-image-3879332236.jpg   Plumbing and drain-image-506872747.jpg
MikeRichardd is offline   Reply With Quote
Old 06-01-2012, 07:00 PM   #2
Master Plumber
Javiles's Avatar
Plumbing and drain
No ..You can however put a protective plastic sleeve(insulator) between them, as long as the two are not touching physically.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 06-01-2012, 07:02 PM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Plumbing and drain
you need to have some sort of separation even if use ten mill tape,pipe insulation.And for the tub drain not sure i understand more info
wctekkk is offline   Reply With Quote
Old 06-01-2012, 07:04 PM   #4
Plumbing and drain
It that an over loaded, inexcessable juntion box I see in that picture?
Old 06-01-2012, 07:20 PM   #5
Plumbing and drain
Well i do have the pile insulation but I'm not sure why it's a problem. Yes the junction box is a mess, I didn't do it, it's Gunna be looked after.
Thx...
So, essentially if I use some insulation I'm ok? Why is it a problem if they touch?
Old 06-01-2012, 07:27 PM   #6
Plumbing and drain
For one thing they will expand and contract at differant rates and make make a noise.
Any two pipes touching like that can make sounds when the water starts and stops.
Old 06-01-2012, 10:25 PM   #7
Plumbing and drain
Ahhh that makes sense. Thx so some insulation around should do the trick?
Old 06-02-2012, 04:44 PM   #8
sacramento plumber
wctekkk's Avatar
Plumbing and drain
the noise would be last concern, how about it leaking after it expand and contract over and over not if when it will happen
The Following User Says Thank You to wctekkk For This Useful Post:
Homerepairguy (06-02-2012)
Plumbing DIY basement drain oops ddguy Plumbing 14 05-20-2012 07:11 PM
shower drain plumbing Arrrgh! Plumbing 14 04-10-2012 10:01 PM
The CELLAR gbwillner Project Showcase 112 02-17-2012 11:00 PM
Plumbing Tub Drain Help! HuskySkull Plumbing 1 02-03-2010 12:29 PM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 08:10 PM
