-   -   Plumbing and drain (http://www.diychatroom.com/f7/plumbing-drain-145603/)
MikeRichardd 06-01-2012 08:53 AM
Plumbing and drain
2 Attachment(s)
Is it acceptable to have the hot and cold pipes touching one another?
Can I install the tub drain on an angle?
Javiles 06-01-2012 06:00 PM
No ..You can however put a protective plastic sleeve(insulator) between them, as long as the two are not touching physically.
wctekkk 06-01-2012 06:02 PM
you need to have some sort of separation even if use ten mill tape,pipe insulation.And for the tub drain not sure i understand more info
joecaption 06-01-2012 06:04 PM
It that an over loaded, inexcessable juntion box I see in that picture?
MikeRichardd 06-01-2012 06:20 PM
Well i do have the pile insulation but I'm not sure why it's a problem. Yes the junction box is a mess, I didn't do it, it's Gunna be looked after.
Thx...
So, essentially if I use some insulation I'm ok? Why is it a problem if they touch?
joecaption 06-01-2012 06:27 PM
For one thing they will expand and contract at differant rates and make make a noise.
Any two pipes touching like that can make sounds when the water starts and stops.
MikeRichardd 06-01-2012 09:25 PM
Ahhh that makes sense. Thx so some insulation around should do the trick?
wctekkk 06-02-2012 03:44 PM
the noise would be last concern, how about it leaking after it expand and contract over and over not if when it will happen
