Plumbing Double Vanity Sinks 36" Apart On Center - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2011, 02:56 PM   #1
Libertarian
Plumbing Double Vanity sinks 36" apart on center
Hello Folks,
I live in Winnipeg Manitoba Canada and I want to know if this plumbing idea I have for my double vanity is legit or not
The sinks in the attached picture are connected to traps that connect to the cross pipe using a 45 Street elbow for the left/end trap and a WYE 45 for the right trap
Any help on this would be much appreciated, thanks!
kurt2 is offline   Reply With Quote
Old 02-01-2011, 09:18 PM   #2
Libertarian
anybody have any comments on this?
is it legit anywhere? will the right hand sink pull water out of the left hand sink's trap when it drains?
Old 02-01-2011, 10:52 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 770
Per UPC each trap needs a vent. I don't know your code.
You can use a common vent by moving your stack between the 2 lavs and using a fixture cross. Or 1 trap to your existing stack by means of a continuous waste between the 2 lavs.
The Following User Says Thank You to TheEplumber For This Useful Post:
kurt2 (02-16-2011)
Old 02-02-2011, 02:40 PM   #4
Libertarian
I don't think I can use "continuous waste" because the drains of the sinks are more than 30 inches away from one another....
how about if I extend the vent to go over one more stud and then down to be between the two traps?
Old 02-02-2011, 07:38 PM   #5
Plumber
Rewards Points: 770
That works. Now both traps share a common vent
Old 02-03-2011, 07:29 PM   #6
Libertarian
another question I have about this is, what angle should the clean out be? 45 degree angle cleanout or a 90 degree angle cleanout?
Old 02-03-2011, 08:07 PM   #7
Plumber
Rewards Points: 770
Usually a tee is installed, but a wye works too.
kurt2 (02-16-2011)
plumbing rough-in for vanity tom31415926 Plumbing 3 12-14-2010 08:38 AM
New vanity sink plumbing doesnt line up Handy Mandy Plumbing 6 04-21-2010 06:07 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Bathroom Marble Vanity Sinks Vic&fred Remodeling 1 10-16-2008 02:47 PM
Need to move around plumbing for vanity.... AllGoNoShow Plumbing 3 05-03-2008 06:13 PM
