Plumbing - Distance Between Hot And Cold Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2013, 01:04 AM   #1
Rewards Points: 12
Lightbulb
Plumbing - distance between hot and cold pipes
Hi All,
Thanks for reading this post. I want to do some moving of my copper pipes, and if I could, I would run the hot and cold pipes parallel to each other with only an inch distance apart from each other. Is this ok, or is there a recommended distance that I should follow?
Best,
Mark
markew is offline   Reply With Quote
Old 11-26-2013, 01:32 AM   #2
Rewards Points: 6,652
You will be fine. BTW, why though so close? Usually you have about a 12" separation.
The Following User Says Thank You to gregzoll For This Useful Post:
markew (11-26-2013)
Old 11-26-2013, 06:45 AM   #3
Rewards Points: 2,638
The only thing is, if you are servicing them in the future (adding a line, shutoff, fixing a leak, etc) you might have a bit of a hard time with another pipe so close.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
markew (11-26-2013)
Old 11-26-2013, 10:05 AM   #4
Rewards Points: 12
Hi, and thanks for the answer. You wrote:
Well, I'm replacing a drop ceiling with a higher drywall one. The pipes are right below the ceiling's beams, so I want to push them back toward the wall as far as possible. If I put them right next to each other, it will allow me to push them farther out of the way.
Old 11-26-2013, 11:22 AM   #5
Then use PEX.
markew (11-26-2013)
Old 11-26-2013, 01:36 PM   #6
Rewards Points: 12
Interesting, GZ, I'll have to look into that. I suppose I could drill holes into the beams to run the PEX through them, and that way I'd have a flat ceiling with no compromise.
Old 11-27-2013, 02:38 PM   #7
Rewards Points: 336
Yep. Imagine trying to cut a pipe with another pipe only 1 inch away.
JKeefe is offline   Reply With Quote
Old 11-29-2013, 07:11 AM   #8
Midget tubing cutter
Size:  12.6 KB use this in tight areas to work with copper pipe
Toothless is offline   Reply With Quote
The Following User Says Thank You to Toothless For This Useful Post:
markew (10-23-2014)
Tags
copper , pipe connection , plumbing
