Plumbing Diagram - Is It Ok? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2013, 06:12 AM   #16
So, no one has any input on this ^^^ question? Should I line the hole with something or not worry about this at all? Owner's manual doesn't say anything about it.
vladens is offline   Reply With Quote
Old 04-24-2013, 09:34 AM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 682
Originally Posted by vladens View Post
Thanks again everyone for the answers.
I have one more question that I hope to get answer to without creating new thread. I dug the hole yesterday for the sewer pit, and noticed right away a little bit of water seeping through the ground. This morning the hole was almost half-way full. OK, I'll pump it out but do I need to do anything to prevent the water from coming there?
I don't think you can do much about it.
When you set the basin, fill it with water so it doesn't float
The Following User Says Thank You to TheEplumber For This Useful Post:
vladens (04-24-2013)
Old 04-24-2013, 11:04 PM   #18
Master Plumber
Javiles's Avatar
Rewards Points: 996
Originally Posted by TheEplumber View Post
These are the kind of questions plumbers argue about during coffee breaks
The best answer I can give is that it depends on your inspector. We do it quite often in my area though.
Ideally, you want to avoid any horizontal venting below the flood rim.
You UPC guys need to get an update on your code man dry venting is for the birds bad news man bad news, we want water at the base of every stack help keep things cleaner, smelling nice, Oh yeah.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
TheEplumber (04-24-2013)
Old 04-26-2013, 01:26 PM   #19
Rewards Points: 1,956
When I am limited by elevation or I exceed maximum trap arm length from a partition, I vent this way-which all my inspectors except
They allow dry flat vents in your code? IPC doesn't.
How does one clean your vent when it fills with feces?
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 04:14 PM
Demo'd Half-Bath, Pics Attached, Any Plumbing? 99altrade Plumbing 12 12-23-2010 09:48 AM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
