-   -   Plumbing diagram - is it ok? (http://www.diychatroom.com/f7/plumbing-diagram-ok-177398/)
vladens 04-17-2013 06:26 PM
Hello, again!
So, I'm planning on putting a bathroom in my basement including installing a a sewer ejector pit & pump. I've come up with a rough plan and would like to ask you all what you think about it. Constructive criticism is welcome.
http://cycle-planet.com/exchange/ebay/vld/plmubing.jpg
This is my 1st time drawing diagram like this, so please don't judge my drawing skills :)
Does general layout look ok? Can I use sanitary cross for 4" pipe where sink & laundry will drain to? What type of 90 degree connectors should I use going from vertical to horizontal runs?
Anything else I should know?
Thanks.
TheEplumber 04-17-2013 07:24 PM
199 Attachment(s)
You did good with the drawing :thumbsup:
I'm going to throw some corrections out there based on UPC. We don't know your location so it's hard to say for sure what your inspector will want-
For beginners, the cross is illegal like that. Best to use two wye's w/45's
No 4" pipe is needed, use 3" instead. That will change your reducers to 1 3x2 to the shower.
A lot of areas don't allow flat vents like you have on the toilet and shower, however, I do it often when grade dictates it. Be sure they roll off above the center line of the drain.
For the 90's- you can't go wrong with long sweeps.
The shower vent can be 1.5" Toilet is 2", horizontal vent is also 2"
Vertical lav vent is 1.5"
Laundry is all wrong- treat your vent as the drain and install your p trap min. 6" above the floor. Then continue the vent line over to the others.
Pump needs a 2" vent
Pump sewage line needs a check valve and a gate or ball valve
The pump line should tie into the existing horizontal line from the top- not vertical.
There, that'll get the conversation rolling :) I'm sure some of the other plumbers here will give their opinions too.
vladens 04-17-2013 09:11 PM
Thanks a LOT for the reply!
I was planning to install one of those in-wall hook-up panel, like this:
http://i111.photobucket.com/albums/n...m/laundry1.jpg
So, I should just hide the p-trap behind the wall as well?
The reason I'm using 4" pipe is because the sewer basin/pump assembly I purchased from Menards has a 4" entry/opening on the side. LINK
My drawing proportions aren't very accurate, they're gonna be much shorter. But still, WC is about 13" away from unfinished wall; how do I avoid horizontal run there?
Check valve was included with the pump kit, I'll just need to get ball valve then. And yes, it was the plan for the line to enter main stack from top (on the angle), I forgot to put that in the drawing.
I'm a little confused by this.... so, lav and shower should start with 1.5" but then turn into 2" because horizontal has to be 2". Why not use all 2" than? Is there good reason or is it just a recommended minimum?
TheEplumber 04-18-2013 01:00 AM
199 Attachment(s)
Pipe the washer like the image I attached
That's fine but you could use a short piece of 4" at the basin, then reduce to 3" after a couple feet
The horizontal vent is OK per my inspector due to structural conditions(slab).
Put the valves outside the basin for future access.
Recommended minimum.
Pipes are sized by Fixture Units and each fixture is sized also. A shower and lav can be on a 1.5" vent. However, a toilet must be on a 2" vent, so the vent needs to be increased at the toilet. All 3 fixtures can still be served by a 2" vent based on their combined Fixture Units. The washer will even fit on the 2"
vladens 04-18-2013 07:02 AM
Thanks again! I will do as you advised.
Is there a recommended height for the check valve? I was thinking to put it as high as possible to reduce the amount of waste water that will sit above the valve (hopefully that would make the valve shutting less noisy)
hammerlane 04-18-2013 07:09 AM
1 Attachment(s)
I dont know if there are any dimensions to your drawing, but the fact that the toilet and shower look a distance away from a nearby wall it appears you will have flat vents before you get to a wat to turn vertical
vladens 04-18-2013 09:07 AM
Thanks! No, my proportions are all off here. It's going to be the standard distance off the wall.
This just a quick 15-minute sketch up, that's why it's not perfect... :)
vladens 04-18-2013 10:02 AM
Does this look better?
http://cycle-planet.com/exchange/eba...ubing_corr.jpg
Still seems like there will be very short flat vent from WC and shower, unless the long 90 is long enough to reach all the way to the wall?! I guess I'll find out when I'll be doing it.
Beepster 04-18-2013 10:16 AM
On my last below grade rough in inspection, I did get nicked for having my vents come off at less than a 45 degree angle. It wasn't flat by no means, just not 45 or higher.
B
TheEplumber 04-18-2013 10:49 AM
199 Attachment(s)
B
When I am limited by elevation or I exceed maximum trap arm length from a partition, I vent this way-which all my inspectors except
vladens 04-18-2013 10:51 AM
Oh, great! This helps a lot!
Beepster 04-18-2013 01:22 PM
I recognize that picture from the Stanley 'How to' book I bought at HD.
Eplumb, I ask this for the benefit of the OP, is it OK to flatten out (get less than 45 degrees) the vent like that before it gets above the flood plane of the item it is venting?
B
TheEplumber 04-18-2013 01:43 PM
199 Attachment(s)
B
These are the kind of questions plumbers argue about during coffee breaks :)
The best answer I can give is that it depends on your inspector. We do it quite often in my area though.
Ideally, you want to avoid any horizontal venting below the flood rim.
Big N8 04-18-2013 01:50 PM
Great discussion here. Good to see what other are doing with odd venting situations.
vladens 04-23-2013 11:09 AM
Thanks again everyone for the answers.
I have one more question that I hope to get answer to without creating new thread. I dug the hole yesterday for the sewer pit, and noticed right away a little bit of water seeping through the ground. This morning the hole was almost half-way full. OK, I'll pump it out but do I need to do anything to prevent the water from coming there?
