Plumbing Code Clarification - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2012, 11:12 AM   #1
Regarding "Size of Fixture Supply", my code states:
The fixture supply pipe shall not terminate more than 24 inches from the point of connection to the fixture.
I'm trying to understand this. I think what confuses me is how "terminate" is defined in this code. I'm taking a guess that,, since all fixtures must have shutoff valves, then this must be the point of "terminatation". So, my personal interpretation is that, the distance between the fixture and shutoff valve cannot be more than 24 inches.
Taking this premise one step further: In a shower install, I would guess that the fixture here is the shower trim (i.e. hot and cold valves) as well as the shower head. It seems the shower head alone would violate code as IT would "terminate" well beyond 24".
Can anyone with experience please comment / clarify. (I'm certain I've got something mixed up here). Thanks, in advance.
nixplix is offline   Reply With Quote
Old 08-14-2012, 01:32 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 672
I"m not familiar with that code but my guess would be the same as yours in regards to faucets- 24" max. developed length on the supply line. You can get shower valves with integral stops, common sense says shower heads would not apply
Old 08-15-2012, 07:22 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
you are basically correct.
y
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Smurf (flex ent) use Code clarification jamiedolan Electrical 7 02-04-2009 12:30 AM
Code Clarification GoyimPersuasion Electrical 24 01-28-2009 03:44 PM
