Plumbing A Clothes Washer. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2013, 08:21 PM   #1
plumbing a clothes washer.
I'm going to in a clothes washer on the ground floor of my house, I was curious what is the code in Iowa?
bjohnson1325 is offline   Reply With Quote
Old 03-20-2013, 08:33 PM   #2
Rewards Points: 14,312
As far as what? Plumbing wiring, location?
Old 03-20-2013, 08:38 PM   #3
Rewards Points: 350
Here's a link to check out. Best to check with your local municipality building inspector for your area, he/she should know.
link here
jmon is offline   Reply With Quote
Old 03-20-2013, 08:47 PM   #4
Pocahontas,ia . Um I guess I know their r different types of pvc like dwv etc is there a certain type I'm to use, do I need a p-trap how far from the floor or can it go below the floor?
Old 03-20-2013, 09:18 PM   #5
Roofmaster
Rewards Points: 2,210
Where are you going to in your clothes washer?
The Following User Says Thank You to jagans For This Useful Post:
fetzer85 (03-20-2013)
Old 03-20-2013, 09:21 PM   #6
Sorry going to move the washer n dryer to the ground floor.
Old 03-20-2013, 11:49 PM   #7
Always learning...
fetzer85's Avatar
Rewards Points: 262
Are they in the basement now? If so could I suggest leaving them there?
fetzer85 is offline   Reply With Quote
Old 03-21-2013, 12:42 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 914
Not sure of Iowa- probably need a 2" drain, 2" trap arm and a 1.5" vent. Also 1/2" H&C water supplies
Old 03-21-2013, 05:14 AM   #9
DIY staff
Rewards Points: 7,174
Local code might also call for a floor drain----every town around here does.
Old 03-21-2013, 07:23 AM   #10
Yes they are in the basement right now. Thank you I asked my wife the same it was of course no so. I don't think its to bad from the main 3inch line in the basement its only getting moved about 18'
Washer Drain Overflows ryanb4614 Plumbing 2 03-20-2012 11:12 PM
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 02:02 PM
Vent size for toilet, vanity, and clothes washer ArtBraendel Plumbing 1 04-10-2011 03:45 PM
fisher & Paykel clothes washer does not spin dnreyes Appliances 2 02-05-2011 08:43 AM
Plumbing: Relocating the washer machine!!!! powder room Plumbing 2 09-04-2010 02:01 PM
