Plumbing Clearance For The Tub. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2011, 05:31 PM   #1
Plumbing clearance for the tub.
I am trying to install a 60" bathtub in the basement. The outside walls are of concrete masonry. The width of the room is 72", by that leaving 12" from the edge of the tub to the masonry wall. The 1 1/2" sewer line is at the edge of the masonry wall and runs horizontal into a backflow preventor.
I understand 12" is not ideal. However, is this enough to install the p-trap and maintain it? It will be tight to perform repairs on the freshwater pipes. However, my concern is more with the drain pipe.
Secondly, are there any pressure coupling that I can use to connect the tub drain to the sewer line -- for easy removal in case I have to replace the trap.
Any advice is appreciated.
djog is offline   Reply With Quote
Old 09-05-2011, 06:10 PM   #2
DIY staff
Rewards Points: 7,174
Any way you can post a photo or sketch?
Or a better description? 12" from what?
Old 09-06-2011, 12:43 PM   #3
Sketch
Sorry, it took me this long to reply. I had to get the drawing done.
The drawing is very small because of size limitations. But as you can see, the distance from the top edge of the tub to the masonry wall is 1'-1". I am worried that this distance may not be adequate for replacing the trap and drain in the future.
Name:  DIY Picture.bmp
Old 09-06-2011, 01:19 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why all if this "in case i have to" stuff. The space is ample, go for it.
You could go across town and build another house just in case your first one should burn down.
XXX
Old 09-06-2011, 02:35 PM   #5
Afraid of messing up
I am afraid that if I mess up, I will not be able to reach behind the wall and fix the trap/drain. I may end up removing the whole tub.
If the house burns down, I am insured. I can go and buy another house with the money. If the sewer flows into the basement, I am not so sure I am am covered.
Old 09-06-2011, 04:53 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Either you have experience with many past failures or you just worry too much. I'll bet it is the latter.
XXX
Old 09-06-2011, 04:56 PM   #7
DIY staff
You are fine---use high quality parts and test your work before you button things up.
Old 09-06-2011, 06:42 PM   #8
Thanks a lot. I appreciate all the feedback. It gives me the confidence to go ahead and finish this project.
Old 09-06-2011, 06:48 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
GO FOR IT!
You can't screw up anything we can't fix.
XXX
Old 09-06-2011, 06:48 PM   #10
DIY staff
Very few tubs have any access at all---many are on second floors above a finished ceiling.
Leaks are rare---with care I am sure you will be fine.---Good fortune--Mike---
Old 09-06-2011, 06:51 PM   #11
DIY staff
Looks like Bud and I will be making a road trip if this doesn't work --so please move to a nice vacation spot.
Old 09-07-2011, 06:15 AM   #12
The bathroom is for my man cave. So what if it stinks a bit. Thanks Mike and Bud for the input.
Tags
bathtub drain , clearance , p-trap , plumbing
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
