Plumbing Check, New 2nd Floor Bath. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2012, 10:37 PM   #1
Rewards Points: 282
Plumbing Check, new 2nd floor bath.
Gonna restart this thread with 3d models rather than start new thread.
this is a new 2nd floor bath, I have about 12" of subfloor space to work with. the tub overflow/drain entrance is a little off in height in the drawing and the P-traps are obviously sized strangely....this is the best i could do with my first try.
Big questions are, do those WYE's look ok, they will be horizontal in relation to the 3" drain pipe...(i understand this is ok because it maintains directional flow, right?).
Toilet will be within about 30 inches of the lav, so it will use that vent. Tub will be vented as shown. (i will have complete access, via the attic, to 3 exterior walls of this bathroom, so that is why the vent goes like that, above the bathroom, its actually the easiest route).
Please assume that all drains and vents are sloped appropriately, and all connections are solid, even though the render may not show that!
THANKS!
jcrack_corn is offline   Reply With Quote
Old 03-02-2012, 02:41 AM   #2
This is find,
However, it's not really necessary ( or professionally preferred) to cut the vent and add additional venting, as long as the horizontal vent pipe is 6" about the highest fixture flood rim. Venting to the roof should always be combined to minimize roof vents, when possible.
cruiser2000 is offline   Reply With Quote
The Following User Says Thank You to cruiser2000 For This Useful Post:
jaydevries (03-02-2012)
Old 03-02-2012, 01:14 PM   #3
Rewards Points: 282
Originally Posted by cruiser2000 View Post
This is find,
Thanks!
now the horizontal branch will not be above the new fixtures...I may have to add a vent for the new bathroom (due to roof slope) and use that existing stack as waste drain and vent (as is).
Old 03-04-2012, 12:56 AM   #4
Rewards Points: 282
here is a new drawing (sorry, i dont have any cad software) showing more accurate representations of how things are arranged. The existing 3" stack on the right cant be used to vent the new bathroom because of the roof slope (it will be below the fixtures).
So the plan is to use it as the waste drain...it will still vent the 1st floor fixtures on that side of the house (vent branch will enter stack ABOVE the new drain tee).
The new 2nd floor bath plumbing will have a 3 inch drain/vent at the lav that goes through the roof. Toilet will be the first fixture, then the lav/vent, then the tub/shower (and it will have a vent branch back to the new 3" stack)...from there it flows to the existing 3" vent stack.
Sound about right? If the new 3" vent is overkill I can reduce to 2"....
Thanks!
Old 03-04-2012, 05:34 AM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
2nd picture looks doable to me depending on how far toilet is from sink
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 03-04-2012, 12:23 PM   #6
Rewards Points: 282
Thanks! It is only about ~24 inches from the lav....the pic is not scale at all! I really just wanted to represent that I would have to run a new Vent for the bath due to the height above the current vent/waste stack, but it would actually drain to the current vent/waste stack.
Old 03-04-2012, 03:44 PM   #7
plummen's Avatar
Old 03-14-2012, 11:10 PM   #8
Rewards Points: 282
---BUMP WITH NEW RENDERS, COPY OF NEW 1st post below, please critique/advise, THANKS---
THANKS!
Old 03-15-2012, 10:09 PM   #9
Rewards Points: 282
bump
any opinions/problems with the proposed plumbing? model looks good to go?
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Check valve on bleach injection not allowing injection scrupul0us Plumbing 0 08-22-2011 06:38 PM
Contractor 5% Off for Cash NOT Check? redavalanche General DIY Discussions 11 05-26-2010 10:28 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 12:41 PM
