Old 12-12-2012, 04:14 PM   #1
plumbing for ceiling showerhead
Ripping out old fiberglass shower tub and want to possibly run the showerhead from wall to ceiling? Any suggestions? Is it as simple as sodering a couple 90 deg elbows? The shower is in second floor. Thank u all in advance for all your feedback!!
er78mph is offline   Reply With Quote
Old 12-12-2012, 09:12 PM   #2
Doing it myself
Alan's Avatar
Everything is simple in theory. Without being there we can only speculate.
What may be easier in your case is to :
1: Mount a wood block where you want the showerhead to come out of the ceiling. Make sure it is level and all that or the showerhead will look like an inebriated plumber installed it on the weekend
2 : Cut off the showerhead fitting you have leaving enough pipe to attach to.
3 : Run a piece of soft copper from cut end to cut end, and solder on couplings and/or 90 as needed .
If you have lots of room overhead, you may be able to eliminate the soft copper, but it does eliminate a solder joint.
If you mount the block, and hire someone to do it, I bet this would be just a trip charge + materials. Moving showerheads is pretty simple business.
Journeyman Plumber
Old 12-12-2012, 11:22 PM   #3
Go back and add your location to your profile.
If this is going to be run though an attic in a really cold area that's makes me worred.
Old 12-12-2012, 11:47 PM   #4
I live in SoCal
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Showerhead: Can Plumbing Tape Hurt? dasjambo Plumbing 1 12-16-2009 05:48 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
