Plumbing Career Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2012, 08:11 PM   #1
plumbing career question
Hi I'm new to the forum. Nice to meet you all. I have a plumbing career question.
I plan to apply to the plumber's union in my area. Which area of expertise in plumbing is best to go into and/or has best job prospects? I wanted to know in advance in case they ask me to choose in the future.
greaselightning is offline   Reply With Quote
Old 01-20-2012, 08:37 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
How many different "areas of expertise" do you think there are in plumbing? Rough-in and finish.
titanoman is offline   Reply With Quote
Old 01-20-2012, 08:41 PM   #3
"Although plumbing, pipelaying, pipefitting, and steamfitting are sometimes considered a single trade, workers generally specialize in one of five areas.
Plumbers install and repair the water, waste disposal, drainage, and gas systems in homes and commercial and industrial buildings. Plumbers also install plumbing fixtures—bathtubs, showers, sinks, and toilets—and appliances such as dishwashers, waste disposers, and water heaters.
Pipelayers lay clay, concrete, plastic, or cast-iron pipe for drains, sewers, water mains, and oil or gas lines. Before laying the pipe, pipelayers prepare and grade the trenches either manually or with machines. After laying the pipe, they weld, glue, cement, or otherwise join the pieces together.
Pipefitters install and repair both high-pressure and low-pressure pipe systems used in manufacturing, in the generation of electricity, and in the heating and cooling of buildings. They also install automatic controls that are increasingly being used to regulate these systems.
Steamfitters install pipe systems that move liquids or gases under high pressure. Sprinklerfitters install automatic fire sprinkler systems in buildings. Plumbers, pipelayers, pipefitters, and steamfitters use many different materials and construction techniques, depending on the type of project.
Residential water systems, for example, incorporate copper, steel, and plastic pipe that can be handled and installed by one or two plumbers. Municipal sewerage systems, by contrast, are made of large cast-iron pipes; installation normally requires crews of pipefitters. Despite these differences, all plumbers, pipelayers, pipefitters, and steamfitters must be able to follow building plans or blueprints and instructions from supervisors, lay out the job, and work efficiently with the materials and tools of their trade. When plumbers working construction install piping in a new house, they work from blueprints or drawings that show the planned location of pipes, plumbing fixtures, and appliances.
Recently, plumbers have become more involved in the design process. Their knowledge of codes and the operation of plumbing systems can cut costs. First they lay out the job to fit the piping into the structure of the house with the least waste of material.
Then they measure and mark areas in which pipes will be installed and connected. Construction plumbers also check for obstructions such as electrical wiring and, if necessary, plan the pipe installation around the problem."
http://www.bls.gov/oco/ocos211.htm
Old 01-20-2012, 08:52 PM   #4
Disabled wood vet
titanoman's Avatar
Originally Posted by greaselightning
"Although plumbing, pipelaying, pipefitting, and steamfitting are sometimes considered a single trade, workers generally specialize in one of five areas. Plumbers install and repair the water, waste disposal, drainage, and gas systems in homes and commercial and industrial buildings. Plumbers also install plumbing fixtures—bathtubs, showers, sinks, and toilets—and appliances such as dishwashers, waste disposers, and water heaters. Pipelayers lay clay, concrete, plastic, or cast-iron pipe for drains, sewers, water mains, and oil or gas lines. Before laying the pipe, pipelayers prepare and grade the trenches either manually or with machines. After laying the pipe, they weld, glue, cement, or otherwise join the pieces together. Pipefitters install and repair both high-pressure and low-pressure pipe systems used in manufacturing, in the generation of electricity, and in the heating and cooling of buildings. They also install automatic controls that are increasingly being used to regulate these systems. Steamfitters install pipe systems that move liquids or gases under high pressure. Sprinklerfitters install automatic fire sprinkler systems in buildings. Plumbers, pipelayers, pipefitters, and steamfitters use many different materials and construction techniques, depending on the type of project. Residential water systems, for example, incorporate copper, steel, and plastic pipe that can be handled and installed by one or two plumbers. Municipal sewerage systems, by contrast, are made of large cast-iron pipes; installation normally requires crews of pipefitters. Despite these differences, all plumbers, pipelayers, pipefitters, and steamfitters must be able to follow building plans or blueprints and instructions from supervisors, lay out the job, and work efficiently with the materials and tools of their trade. When plumbers working construction install piping in a new house, they work from blueprints or drawings that show the planned location of pipes, plumbing fixtures, and appliances. Recently, plumbers have become more involved in the design process. Their knowledge of codes and the operation of plumbing systems can cut costs. First they lay out the job to fit the piping into the structure of the house with the least waste of material. Then they measure and mark areas in which pipes will be installed and connected. Construction plumbers also check for obstructions such as electrical wiring and, if necessary, plan the pipe installation around the problem."
Wow. You've done your research.
I didn't know what a pipefitter or a steamfitter was, so I learned something today.
Good luck with your ventures, hope your business is a raging success.
Old 01-20-2012, 09:12 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 546
I think you need to focus on getting into the hall first- this may be tough in the current economy. Then try to be an all around, good apprentice and do more then your journeyman says to do- and don't talk back to him As you go through a 5 yr apprenticeship, you'll either find your niche or you will adapt to whats available.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
plummen (01-20-2012), yuri (01-21-2012)
Old 01-20-2012, 09:46 PM   #6
I'm not sure how it is in plumbing, but when I applied to an HVAC union there was a check box questionnaire that ask you if you want to go into air balancing, sheet metal, or service. I was thinking maybe they ask something like that too in the plumber's union. If so, I was just wondering which area of expertise would be the best to apply for.
Old 01-20-2012, 10:48 PM   #7
Disabled wood vet
titanoman's Avatar
I think commercial would be the way to go. I don't know if they separate that or not.
And I assumed the apprentiship would be 4 years.
Old 01-20-2012, 11:21 PM   #8
I couldn't tell you what the best job prospects for the future are but I 'd like to ask you a question. What interests you the most about plumbing? Unions tend to mostly work on large scale commercial/industrial projects, at least around here they do, and so there's opportunities for all kinds of 'specialized' tickets like; sprinkler fitters, steam fitters, gas fitters, medical gas installers and on and on and on.
As EPlumber says get the apprenticeship first, keep your mouth shut & ears open, phone off & work your ass off. You're bound to find something that interests you but you have to be committed and open to learning all the time. That's what separates the good trades people from the hacks.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
yuri (01-21-2012)
Old 01-20-2012, 11:51 PM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id say dont just limit yourself to union shops unless you want to spend a lot of bench time till you get some time under your belt.
In the last 30 years ive done electrical/hvac/plumbing/utility installs and repairs/pipe fitting and steam fitting/boiler work.
I ran my own shop for last 15 years,now Im pretty much semi retired picking and choosing the projects I want to do when I want to do them.
If I would have stayed in the electricians union doing just one thing when I was young I would have missed out on a lot of opportunities to learn new skills to make myself more usefull.
Dont get stuck in a rut where you only have one skill,it makes you easy to replace
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
yuri (01-21-2012)
Old 01-21-2012, 12:23 AM   #10
Do some research and find out what YOU are interested in. There may be an "introduction to trades" course that you can take at your local trades/technical school that you can take. I know a few guys who have taken that sort of class and it helped them go into the trade best suited to them, even though they wanted to pursue a different trade previously. I didn't take such a course, but learned what I wanted to do through work experience. I, too, was interested in plumbing, as well as electrical and sheet metal, and was eventually offered an apprenticeship with a small residential/light commercial HVAC company, and was offered either a sheet metal or gas fitting apprenticeship. Since I like having a great deal of responsibility, and had applied to the local gas company because I assumed a large utility company would be a good one to work for, I chose gas. This was a small company, so I learned many different skills from gas service/installations and air conditioning service/installations to sheet metal and also saw how other mechanical trades like plumbers, sprinkler fitters and electricians work. I learned a lot. I eventually learned that gas was what I wanted to specialize in, and eventually went to work for the local gas utility. I couldn't be happier with where I ended up. Despite all the benefits that I get being an IBEW union gas utility employee, if I didn't absolutely love what I'm doing, I'd be miserable. Bottom line: do what you love, or at least really like, lol.
hvac benny is offline   Reply With Quote
The Following 2 Users Say Thank You to hvac benny For This Useful Post:
plummen (01-21-2012), yuri (01-21-2012)
Old 01-21-2012, 10:33 AM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Service work will always be there. Drain cleaning is a big one. Playing with people's poop can be eye opening.
Journeyman Plumber
Old 01-21-2012, 10:53 AM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 1,778
Also depends on how physically strong you are and whether you are willing to take risks with your safety, health, back etc. I have done everything from steam fitting in a large hospital, large chillers, working off ladders on unit heaters in the air and off forklifts etc etc. Steam and sprinkler fitting and large commercial stuff is not for every guy unless he is built for it. Residential is a lot safer and for some guys less bullwork which suits them fine. Other guys like challenges and bigger stuff. Residential service and you may have to work "on call" after hours a lot and that can wreck marriages and some guys hate it. Commercial / industrial can involve lots of out of town work and being in camps etc and hard on marriages. Lots of food for thought before you get into it. Feel free to ask more questions.
It is INCREDIBLY important to have a good attitude and work ethic when apprenticing as very few Journeyman tolerate an attitude from them. Myself included. If you don't then they won't teach you anything or help you well and you will learn the back end of a shovel real well.
The Following 3 Users Say Thank You to yuri For This Useful Post:
plumber666 (01-22-2012), plummen (01-21-2012), TheEplumber (01-21-2012)
Old 01-21-2012, 11:15 AM   #13
Probably what interest me most about plumbing is not working in an office all day everyday . Actually it's probably the fact that I can get paid as I learn thru an apprenticeship, it's a much better deal than college. I like a good work/life balance. Hope that I can one day have my own company truck, travel to job sites, fix their problems, have the paycheck waiting for me on the counter sort to speak, then go home at the end of the day. Also make the big $$$$ on commercial projects, etc. That, and I also think it's a great field to go into. Thanks in advance for the advice guys.
Old 01-21-2012, 11:43 AM   #14
Hvac Pro
yuri's Avatar
Hate to burst any bubble but a lot of commercial or industrial work can be either a feast or a famine. especially with a union you go to the back of the line/hiring hall when the big project ends. then it can take a long time B4 they call you or one of the hundred other apprentices like yourself looking for work. the $$ are better but it is totally at the whims of the economy. residential is very steady as everyone needs a toilet and unless you are in new home construction it can be very steady work. no job is perfect. I should have been born rich instead of handsome.
The Following User Says Thank You to yuri For This Useful Post:
Old 01-21-2012, 12:39 PM   #15
Plumber
Rewards Points: 546
Spend the summer in a ditch laying large pipe or a winter on concrete decks several stories high with no windows and sub freezing temps and that office looks kinda nice
The Following User Says Thank You to TheEplumber For This Useful Post:
Help please! New house plumbing question Cdessel Plumbing 1 12-02-2011 11:28 PM
1st-time home buyer novice plumbing renovation question dakotajoe Plumbing 6 06-28-2011 11:50 AM
Adding a second vanity in a ensuit. Plumbing question? yrivard Plumbing 1 02-06-2011 02:59 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
