Plumbing Books - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-28-2008, 01:45 PM   #1
Rewards Points: 101
Plumbing Books
I'm looking for some good plumbing reference/how-to type books. Others in the forum have recommended the Taunton's For Pros By Pros series for carpentry type references. Was wondering if they are good for plumbing as well or if there is a better series.
jte1130 is offline   Reply With Quote
Old 05-28-2008, 02:25 PM   #2
I blame ProWallGuy
Rewards Points: 150
What type of plumbing?
Double A is offline   Reply With Quote
Old 05-28-2008, 02:41 PM   #3
Rewards Points: 101
Household. Not sure if you meant something more specific then that.
I found this book:
http://www.delmarlearning.com/browse...sbn=1401848915
Seems like a textbook but very detailed from the excerpts.
Old 05-28-2008, 02:46 PM   #4
Registered User
Termite's Avatar
Taunton's books are excellent, although I haven't seen the plumbing one. Lots of pictures for those of us that learn best through seeing something being done.
Old 05-28-2008, 02:53 PM   #5
Rewards Points: 101
I would assume the plumbing book is the same. I was thinking of building my home diy library with the Taunton books. Since I have some plumbing projects on my list I figured I'd start with that one. I agree with lots of pictures. Always best to be able to vizualize how something is done.
Old 05-28-2008, 04:43 PM   #6
Journeyman Plumber
Ron The Plumber's Avatar
If you plan on building your own home, make sure you read the most important book out there, your code book, without it you won't get past the inspections.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-29-2008, 09:07 AM   #7
Rewards Points: 101
I went ahead and ordered the Taunton book. I'll give a review once I have it.
Old 05-29-2008, 11:01 AM   #8
Registered User
Termite's Avatar
Very true!
For the ICC codes, there are spiral-bound "code check" quick reference guides that highlight various codes (plumbing, electrical, etc.) depending on which one you buy. They're intended for everyone from homeowners to builders to inspectors, and are a quick reference guide. The home depot here sells them, or you can get them from www.iccsafe.org.
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 09:36 PM
Ant's through slab plumbing aace Pest Control 4 02-13-2008 03:48 PM
Shower Plumbing Ron Plumbing 1 08-15-2007 11:38 AM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
