Plumbing Bid - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-26-2006, 04:27 PM   #1
Plumbing bid
How is a plumbing job bidded out? Plumber advised bid is per fixture
paultaylor is offline   Reply With Quote
Old 10-26-2006, 05:31 PM   #2
A lot depends on what has to be done to access where the lines will be run. Takes longer if he has to drill holes in studs etc. If the house is new construction, the cost would be lower as it would be done before walls are covered with drywall. Then a standard "per fixture" formula could be used. Local wages and material cost can boost the cost and since we are from all over, geographically, estimating your cost would be difficult.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-26-2006, 06:28 PM   #3
Thankyou for the information, that is really helpful!
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 01:41 PM
Shower Plumbing Ron Plumbing 1 08-15-2007 12:38 PM
rough in plumbing psiter Plumbing 5 08-23-2006 06:44 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
New home plumbing cost wdsfr1968 Plumbing 7 07-28-2006 10:41 AM
