Plumbing Bath Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2012, 10:10 AM   #1
I am remodeling a bathroom and installing a new faucet in the jetted tub. The hardware set and instructions lead you to a flexible hookup (threaded SS hoses to connect the parts). The current setup is plumbed with copper- no flexible connections. It would be easier to use the flexible hose connections but the area will not be easily accessible after the wood panel is installed in front of the tub. Question is does code and/or good plumbing practice allow for use of flexible hose connections in areas that are not easily accesssed?
msadams1 is offline   Reply With Quote
Old 09-02-2012, 12:51 PM   #2
Honestly, you should have a removable panel there anyway. You want access in case something goes wrong and you need to repair/replace that faucet. Use the flex connectors but put that panel on with hinges or in some way that makes it removable.
idlplumb is offline   Reply With Quote
Old 09-02-2012, 12:56 PM   #3
Rewards Points: 13,250
I made my panel from the floor to just above the shower valve.
That way I can get under the tub to work on the drain or have access to the back side of the valve.
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 10:31 AM
Basement Plumbing for 1/2 bath..please help.. heracles Plumbing 13 03-28-2010 09:35 PM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 06:05 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
