Old 10-17-2011, 11:26 PM   #1
plumbing a basement sink
Bought a pump box for under the utility sink with 1/3 rd HP pump, but it requires a vent pipe. How can I tell which pipe overhead is a vent that I can tap into?
itsbob is offline   Reply With Quote
Old 10-18-2011, 12:12 AM   #2
Persona Non Grata
VIPlumber's Avatar
If you can post a pic, we'll try to help you figure it out.
VIPlumber is offline   Reply With Quote
Old 10-18-2011, 11:01 AM   #3
I'll work on that tonight thanks..
BUT in the meantime, I THINK I found a vent, but not 100% sure. The floor above is a toilet, and can find the drain line for it, Y'd to it is a smaller pipe (maybe 2") that is Y'd in the opposite direction of the drain, and goes up into the wall. It's attached downstream from the toilet about a foot - 18 inches..and from there it's probably 8 feet until it attaches to the main drain. I'm assuming a toilet drain would require a vent.
The only issue I have it if it's a vent it's Y'd level and parrallel to the drain pipe..
But I will try to get pictures..
Thanks again!
Old 10-18-2011, 01:26 PM   #4
Just use an air admittance valve instead.
Old 10-18-2011, 09:17 PM   #5
Picture is of the toilet on the floor above and what I guess is the vent line for it?
the other attachment is where the same toilet drain connects to the main going out of the house.
Old 10-18-2011, 10:26 PM   #6
call me E
TheEplumber's Avatar
I'm sorry to say that none of that is usable for the pump venting. I also do not recommend an AAV or Studor on the pump- wrong application.
The vent for the pump must connect 6" above the toilet or other fixtures on the main floor. If you connect to the toilet vent in the ceiling you will probably back drain to the pump when you flush, not to mention it violates most or all plumbing codes.
Do you have a floor drain or other plumbing in the basement?
Old 10-19-2011, 10:29 AM   #7
Doing it myself
Alan's Avatar
Agree completely, and actually here we MUST go out through the roof separately with our pump vents.
Journeyman Plumber
Old 10-19-2011, 10:01 PM   #8
question does your plumbing code allow for automatic venting in this case...????if so would be easy install and fix...
Old 10-19-2011, 10:23 PM   #9
Doing it myself
Alan's Avatar
I really doubt that any jurisdictions would allow that on a pump.
Maybe in mexico. . .
Journeyman Plumber
Old 10-20-2011, 12:26 AM   #10
call me E
As grey water is pumped from a basin, it needs to draw in air to replace the water. The opposite is true also- as water enters the tank, air needs to escape. An auto vent is not designed for that purpose. It doesn't work, I've tried it.
Old 10-20-2011, 10:02 AM   #11
Doing it myself
Alan's Avatar
I lol'ed.
Journeyman Plumber
Basement plumbing layout advice repoocaj Plumbing 2 09-29-2011 10:56 PM
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 12:49 PM
Basement Plumbing Rough-In... elliot Plumbing 0 09-17-2011 03:46 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
