Plumbing A Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2011, 07:50 AM   #1
Rewards Points: 150
Plumbing a basement bathroom
Hi folks,
I am finishing my basement and putting in a half bathroom. I have PEX plumbing for the entire house (manifold is on other side of basement half bath wall). I also have superior walls in the basement with the preformed holes in the studs.
My questions are;
1) is it "legal" and OK to run two 1/2" PEX lines through a single hole in the stud?
2) Does the toilet need to be on a cold supply line than the sink?
As always, thanks for all the help!
stradt03 is offline   Reply With Quote
Old 10-18-2011, 07:22 PM   #2
1) I'm sure it's "legal", but it's not OK. When the hot and cold water lines share the same holes, the heat from the hot pipe will transfer to the cold line (after you shut them off and the water is just sitting in the lines). When the next user turns the cold tap on, the water will come out warm or even hot for a few seconds before the cold water forces it all out of the line. It's also advisable (even in the basement) to keep the water lines out of the exterior walls. Running them through the ceiling joists is a better option.
2) the toilet supply can tee off the line that feeds the sink.
Ishmael is offline   Reply With Quote
basement bathroom breiding200 Plumbing 2 03-15-2011 03:05 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 07:13 PM
Basement bathroom under slab plumbing garynlisa Plumbing 0 02-01-2010 10:04 AM
Venting of basement plumbing fixtures david.plymouth Plumbing 3 01-18-2010 05:46 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
