Plumbing In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2013, 01:54 PM   #1
Plumbing in basement
Hello plumbers!
Im trying to install plumbing in the basement for a bathroom I'm finishing. The water line is in the ceiling, and the place where I want to place the sink, and toilet are against the outside wall. Is it safe to run the plumbing line along an outside wall?
I was hoping this would be OK because:
a.) the basement is below ground
b.) I would run the pipe between the insulation and the drywall.
I should mention I'm in Alberta, and so there are some extreme conditions outside.
Thanks!
ithm is offline   Reply With Quote
Old 04-10-2013, 05:32 AM   #2
DIY staff
Rewards Points: 7,174
You should be fine--"IF"---you have proper framing---insulation---air stopped any outside penetrations-----
What pipe are you planning to use? PEX can take freezing ,if it is allowed in your area.
However, I believe you will be fine if you take extra care in placing you feed lines.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ithm (04-12-2013), jaydevries (04-10-2013)
accessing plumbing under basement floor for bath jimmyfloyd Plumbing 3 01-20-2012 10:49 AM
Plumbing runs on basement outside wall n0c7 Plumbing 8 01-19-2012 05:22 PM
Extending Basement Plumbing rhys Plumbing 1 12-09-2011 07:19 AM
Basement Suite Plumbing krenkem Plumbing 0 05-25-2011 08:47 PM
How to design plumbing drainage in basement sonicsmooth Plumbing 0 02-02-2011 01:55 AM
