Old 12-30-2010, 08:39 PM   #1
Plumbing alignment issue (plastic to copper)
Hey all!
New to this forum, and attempting a bathtub installation. We removed the existing cast iron tub (ugh!) and once we laid down the new tub, our plastic 1-1/2" plastic piping was about a 1/2" too short and ALSO and more importantly perhaps, missed LEFT by 1-1/2"!! (So much for a standard fit)
Any suggestions on how to make this work??
I've attached a photo of what we're stuck with at this point.
Thanks in advance!
Mike
muhren is offline   Reply With Quote
Old 12-30-2010, 08:45 PM   #2
Owner
LateralConcepts's Avatar
You need to cut the copper pipe behind the p-trap, then build a new trap with ABS or PVC. Make the connection between the copper with a no-hub coupling (copper x pl)
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 12-30-2010, 08:45 PM   #3
Just call me Andrew
Why not just cut the copper to the right, and transition to pvc on the horizontal part?
Edit: Lateral...beat me to it!
Andrew
secutanudu is offline   Reply With Quote
Old 12-30-2010, 09:12 PM   #4
Thanks for the advice on this! Next question is the length of drop I currently have...enough? If not, how would I make that fit?
Thanks in advance again!
M
Old 12-30-2010, 09:20 PM   #5
Owner
Probably not. Kinda hard to tell from the picture. You'll need a slip joint extension tube
Lateral
(208) 818-8241
Toilet Plumbing Issue jgb Plumbing 0 04-29-2010 12:09 PM
Advice/thoughts on plumbing issue mrmagoo_83 Plumbing 10 03-26-2010 09:43 AM
plumbing copper for HVAC refrigerant lines? Mike in Arkansas HVAC 9 03-21-2010 09:52 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Plumbing Issue construction wife Plumbing 3 05-25-2008 12:42 PM
